sheikh
Hello Dears
I wrote a vhdl code for this equation V= (a + b + c)*3, ( a and b and c are variables). When I simulate it, and give the registers load in test bench, it work correctly, but when I merge this code with a control unit and produce load signals with this control unit the simulation out put doesn't show the first input, except the inputs are applied after loading the input registers ( fig 2). I test my control unit and it produces the load signals in same time with when I insert load signal by hand in vhdl test code? Could you please explain where is my mistake?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity V_DataPath is
port (
CLK : in STD_LOGIC;
a : in STD_LOGIC_VECTOR(31 downto 0);
b : in STD_LOGIC_VECTOR(31 downto 0);
c : in STD_LOGIC_VECTOR(31 downto 0);
L_a : in STD_LOGIC;
L_b : in STD_LOGIC;
L_c : in STD_LOGIC;
L_c_1 : in STD_LOGIC;
L_C1 : in STD_LOGIC;
L_C2 : in STD_LOGIC;
L_V : in STD_LOGIC;
V_Value : out STD_LOGIC_VECTOR(31 downto 0)
End;
architecture str of V_DataPath is
-- Component Declaration.
Component LOADABLE_REGISTER
port (
CLK: in STD_LOGIC;
LOAD: in STD_LOGIC;
RESET: in STD_LOGIC;
INPUT: in STD_LOGIC_VECTOR (31 downto 0);
OUTPUT: out STD_LOGIC_VECTOR (31 downto 0)
end Component;
-- Signal Declaration
Signal a_Sig : STD_LOGIC_VECTOR(31 downto 0);
Signal b_Sig : STD_LOGIC_VECTOR(31 downto 0);
Signal c_Sig : STD_LOGIC_VECTOR(31 downto 0);
Signal B_1_sig : STD_LOGIC_VECTOR(31 downto 0);
Signal C1_Sig : STD_LOGIC_VECTOR(31 downto 0);
Signal C2_Sig : STD_LOGIC_VECTOR(31 downto 0);
Signal out_add_1 : STD_LOGIC_VECTOR(31 downto 0);
Signal out_add_2 : STD_LOGIC_VECTOR(31 downto 0);
Signal out_mult : STD_LOGIC_VECTOR(63 downto 0);
Signal out_mult_1 : STD_LOGIC_VECTOR(31 downto 0);
Signal V_Value_sig: STD_LOGIC_VECTOR(31 downto 0);
-- Fix Value
Signal a : STD_LOGIC_VECTOR(31 downto 0) := (0 => '1',1=>'1', others =>'0');
Begin
-- Reg_a
Reg_a : LOADABLE_REGISTER port map
( INPUT => a, Load => L_a, RESET => RESET, clk => clk, OUTPUT => a_Sig
-- Reg_b
Reg_b : LOADABLE_REGISTER port map
( INPUT => b, Load => L_b, RESET => RESET, clk => clk, OUTPUT => b_Sig
-- Reg_c
Reg_c : LOADABLE_REGISTER port map
( INPUT => c, Load => L_c, RESET => RESET, clk => clk, OUTPUT => c_Sig
-- 1st ADD
out_add_1 <= a_Sig + b_Sig;
-- Reg_c_1
Reg_c_1 : LOADABLE_REGISTER port map
( INPUT => c_Sig, Load => L_c_1, RESET => RESET, clk => clk, OUTPUT => c_1_sig
-- Reg_C1
Reg_C1 : LOADABLE_REGISTER port map
( INPUT => out_add_1, Load => L_C1, RESET => RESET, clk => clk, OUTPUT => C1_sig
-- 2nd ADD
out_add_2 <= c_1_sig + C1_sig;
-- Reg_C2
Reg_C2 : LOADABLE_REGISTER port map
( INPUT => out_add_2, Load => L_C2, RESET => RESET, clk => clk, OUTPUT => C2_sig
-- 1st multiplier
out_mult <= C2_sig * a;
out_mult_1 <= out_mult (31 downto 0);
-- Reg_V
Reg_V : LOADABLE_REGISTER port map
( INPUT => out_mult_1, Load => L_V, RESET => RESET, clk => clk, OUTPUT => V_Value
End str;
library IEEE;
entity V_controller is
Port ( CLR : in STD_LOGIC;
CLK : in STD_LOGIC;
END_Frame : in STD_LOGIC;
L_a : out STD_LOGIC;
L_b : out STD_LOGIC;
L_c : out STD_LOGIC;
L_c_1 : out STD_LOGIC;
L_C1 : out STD_LOGIC;
L_C2 : out STD_LOGIC;
L_V : out STD_LOGIC;
RESULT_READY : out STD_LOGIC
end V_controller;
architecture state_machine of V_controller is
TYPE TYPE_STATE is (RESET, T0, T1, T2, T3, FINISH);
signal next_state : TYPE_STATE;
signal present_state : TYPE_STATE;
----- States Signals -----
signal T0_state : STD_LOGIC;
signal T1_state : STD_LOGIC;
signal T2_state : STD_LOGIC;
signal T3_state : STD_LOGIC;
begin
------------------------------ sequential part of state machine -----------------
sequential : process(CLK, next_state, CLR)
begin
if(CLR = '1')then
present_state <= RESET;
elsif(CLK = '1' and CLK'event)then
present_state <= next_state;
end if;
end process sequential;
------------------------ combinational part of state machine---------------------
combinational : process(END_Frame, present_state)
begin
case present_state is
when RESET =>
next_state <= T0;
when T0 =>
next_state <= T1;
when T1 =>
next_state <= T2;
when T2 =>
next_state <= T3;
when T3 =>
if (END_Frame = '1' ) THEN
next_state <= FINISH;
else
next_state <= T3;
end if;
when FINISH =>
when others =>
end case;
end process combinational;
--- signal assignment ---
T0_state <= '1' when (present_state = T0) else '0';
T1_state <= '1' when (present_state = T1) else '0';
T2_state <= '1' when (present_state = T2) else '0';
T3_state <= '1' when (present_state = T3) else '0';
--- Load Sequences ---
L_a <= T0_State or T1_State or T2_State or T3_State;
L_b <= T0_State or T1_State or T2_State or T3_State;
L_c <= T0_State or T1_State or T2_State or T3_State;
L_c_1 <= T1_State or T2_State or T3_State;
L_C1 <= T1_State or T2_State or T3_State;
L_C2 <= T2_State or T3_State;
L_V <= T3_State;
RESULT_READY <= '1' when (present_state = FINISH) else '0';
end state_machine;
