Problem with code for a digital thermometer & thermostat model using ds1620 and 89c51
abbas1707
Full Member level 4
hi,
i made a digital thermometer & thermostat model using ds1620 and 89c51 on proteus. but there is a problem..
only value put in for high temprature limit is working and nothing happens for low temperature limit...means alarm goes on when temperature rises 50°c and nothing happens when temperature goes below 20°c. i have tried a lot but failed to correct the code......can anyone here correct the code:|
Re: code problem
Hi
I think there is no problem with code
You missed a connection
Put a diode form pin6 of ds1620 to the base of transistor
Regards
Nandhu
Re: code problem
thats not a connection problem.. infact high signal is not appearing at pin 6 of ds1620 when temperature goes beloow 20°c.......
problem is some where in the code but cant find where:!:
Re: code problem
I have tested and help you do some modification on your code. There are 2 parts:
1) You haven't do the MSB bit checking. This MSB bit is to tell you whether is negative number, 100h = -1.
unsigned char read(void)
 	unsigned char i = 0;
	unsigned char dat = 0;
	for(i=0; i<9; i++)
		if(i<=LSBBYTE) // LSB
			dat = dat | (readBit()<<i);
			temp_dat = dat;
		else if(readBit()==0x01) // MSB
			datt = 256 - temp_dat;
	rst = 0;
	return dat;
2)
void write(unsigned char a)
 	unsigned char i;
	for(i=0; i<8; i++)
		writeBit(a & 0x01); a>>=1;
Good Luck.
