Problem with cable connection while programming Xilinx FPGA kit
vivek_raj_verma
Junior Member level 2
hi there,
I ve encoutered one problem while programming xilinx FPGA kit. It shows cable is not connected. when i do autodetect cable it shows cable is connected but when i say program then again it says that cable isnot connected.
what cud be the problem???
help, i m new to it.
programming for the first time.
vivek
echo47
Advanced Member level 5
USA
help needed
Xilinx has many FPGA kits. Which one do you have?
I'm guessing you are using Xilinx ISE iMPACT software and the Xilinx Parallel Cable IV. Correct?
iMPACT displays a lot of confusing messages as it searches the parallel port, USB port, and the JTAG chain. If you show us all the messages, maybe someone can see what's going wrong.
Please use a more descriptive message subject than "help needed".
Iouri
Advanced Member level 2
help needed
Do you have power on you board?
How clean is a power supply?
vivek_raj_verma
Re: help needed
thanks ,
i ll be posting the messeges what it gives and the xilinx kit information soon.
shmoib
Junior Member level 3
Re: help needed
i think this may arise if you are not the host admin
eziggurat
Full Member level 6
Re: help needed
I get this message quite often, but my problem is mainly due to the JTAG flylead not connected properly.
vivek_raj_verma said:
hi there,
vivek
