Serwan Bamerni
Member level 2
I using Xilinx system generator blocks in Matlab.
I simply using only a black box with a gateway in and gateway out.
The code for the black box is very simple and work correctly with ISE design suite
but unfortunately it doesn't work with the matlab system generator.
I got the following error message
can any one help me what is the wrong with this code and what change should I do so the model work correctly
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.ALL;
entity test44_vhdl is
Port ( row : in std_logic_vector (1 downto 0);
slice : out std_logic_vector (3 downto 0));
end test44_vhdl;
architecture Behavioral of test44_vhdl is
type oneD is array (1 to 3) of integer range 0 to 15;
constant table: oneD := (3, 9, 13);
begin
slice <= std_logic_vector(to_unsigned(table(to_integer(unsigned(row))), slice'length));
end Behavioral;
Exception: ISE Simulator Simulation failed during initialization.
