Vlad Cretu
Newbie level 6
- Joined
- Jul 12, 2014
- Messages
- 14
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,385
Hello,
I open the start simulation window, select the testbench with the appropriate resolution. I select the sdf file. and enter the region.
In the images you can see the setup and the simulation started without the sdf file.
The structure of the system is the following:
MFCV_system_alpha_tb -> MFCV_system_top (UUTT)
and the MFCV_system_top is generated by encounter together with the sdf file.
I get the following error for every instance in the MFCV_system_top : Failed to find INSTANCE '\UUT.I89.I1.I21 '
