[SOLVED] problem with ADC - simple solar tracker isnt working
Kaleborg
Member level 4
read_adc dont work
Hello!
I'm trying to build simple solar tracker but i cant figure out why this isnt working.
#include <pic.h>
#include "my include.h"
#include "MyADC.h"
#include "delay.h"
#include "motor_control.h"
//#define 	_XTAL_FREQ	4000000
__CONFIG( XT & WDTDIS & PWRTDIS & BORDIS & UNPROTECT );
void main(void){
	unsigned long left_ldr_val, right_ldr_val, i;
	TRISA|=0x0f;
	ANSEL0=0x3;
	ANSEL1=0;
//	ADCON0=0;
	CM2CON0=0;
	OPA1CON=0;
	INIT_MOTO();
	MOTO_PWM();
	ADC_INIT();
	while(TRUE){
		left_ldr_val= READ_ADC(0)&0x03FF;
		//DelayUs(10);
		left_ldr_val=1024-left_ldr_val;
		DelayUs(10);
		right_ldr_val= READ_ADC(1)&0x03FF;
		//DelayUs(10);
		right_ldr_val=1024-right_ldr_val;
		DelayUs(10);
		//for(i=0; i<0x0200; i++)
		while(left_ldr_val>right_ldr_val){
			GO_LEFT();
		while(left_ldr_val<right_ldr_val){
			GO_RIGHT();
		DelayUs(10);
The problem is that motor keeps rotating in one direction as if pic only read channel 0 of the adc and did not bother read the second channel. Can anybody help me sort it out.
The method for reading ADC is this:
unsigned long READ_ADC(unsigned char channel){
	unsigned long ADC_result;
	channel&=0x07;				//get rid of unwanted bits
	ADCON0&=0xC5;				//Clear current channel selection
	ADCON0|=(channel << 3); 	//Set new channel
	DelayUs(100);
	GODONE = 1;					//Start the thing
	while(GODONE);				//Wait till its done
	ADC_result=(ADRESH<<8 + ADRESL);
	//ADC_result <<8;
	//ADC_result=ADRESL;
	return ADC_result;
I did check the connections and all seems to be correct.
So i suspect that my problem is software.
I aprecieate all help.
Thanks in advance
opa1con
rewrite the below code
         GO_LEFT();
         GO_RIGHT();
to
      if (left_ldr_val > right_ldr_val)
           GO_LEFT();
      else if (left_ldr_val < right_ldr_val)
           GO_RIGHT();
Hope this helps!!
Nishal
    Kaleborg
Re: problem with ADC
I changed the code as you said and it's working perfectly now!!
I wasn't even loking at that part of code, i was convinced that adc chanells were the problem.
Thanks for help Nishal
Hi I am currently working on a solar tracker too. I would be really appreciate if you could contact me by email or pm. Thx
