Problem with a math equation (16f877a)
martinisonline
Member level 2
Portugal
Math problem??...16f877a
Hy...
I'm implementing a temperature meter based in the ds1820.
It works great, but now, i 'm trying to do the high resolution mode.
i need to do a math equation that is:
temp = temp_read - 0.25 + (count_per_C - count_remain)/count_per_C
these variables are int. The 'temp' must be float because the division, right?
Can i do a divison of 2 int and return 1 float?
viewing at hyperterminal, the variable 'temp' is always 0...
I am using CCS and 16F877A.
Greats...
Re: Math problem??...16f877a
Read Dallas AN105 : **broken link removed**
First page 10 for definition of "res' and "LSB"
Then page 18 for float CalcHiResTemp(int temp9, int count_per_degree, int count_remain)
It's all you need including casting.
Do you want to know why I like more parsing at low level rather than C ?
The answer is tight code and beautiful of math :
You still need floating point maths ?
Information : while(true){ printf("Very");} usefull...:)
Tanks...
it's more dificult, but more "inside the question"...:)
