Problem wirh DDR SDRAM controller targeting on board XUPV2P, Virtex-II Pro
connit1986
Newbie level 2
I’m implementing DDR SDRAM controller targeting on board xupv2p, virtex-II pro. DDR SDRAM: KVR400x64C3A/256 256MB
I have modulated with modelsim at all levels to “post and route” with model ddr.v of Xilinx and I received good result (be able to write and read). But I had trouble while targeting on board. I used chipscope to observe and I don’t see result while reading (ddr_dq: data when read; ddr_dqs: stroble ).
Currently, I suspect that: ddr sdram with range of clock: 5ns-10ns; but board supports max 100MHZ. I use DCM to make output clk2x with clock input 100MHZ. Could you please give me some advices where I did wrong and how to repair it. Thank you very much for your time.
DDR question
Your controller must also supplu DDR clock to your memory chip, and that should be an output from the DDR flip-flop which must be instantiated in your VHDL code.
refer here:
DDR question
you can try your ddr controller at a lower freq to see whether it can work well.
