I want to program my MAX EPM7128SLC84-15 through its JTAG port
I have purchased ByteBlasterMW from Altera and using MAXPlus II 10.23
But SW gives me a message ( Unrecognized device or socket is empty )
I don't know why ?
The connections with TMS,TCK,TDI and TDO are directly from the JTAG to the chip but I didn't put pull up resistors ...
My question is :
1- Did any body face this problem before ?
2- Should I put pull up resistors to the JTAG pins ?
Waiting for your recommenditions
the ByteBlaster datasheet in this site **broken link removed**
don't contain any information about the pullup/down resisors that should be connected with the JTAG , the only schematic shown in page 4 is the schematic of the Blaster itself !
If you have a link for such info plz help
A great chance is your CPLD's JTAG function is disabled. I got a chip with the same problem and the only solution I know is erase the whole chip with parallel programmer. Please inform me if anybody know some way to earse this chip without using commercial programmer.
Thankx Epegic , but the problem is that I want to read the chip not to write on it so , I can't erase it first !
I have connected the pull up / pull down resistors as mentioned in the AN95 but still I have message ( Unrecognized device or socket is empty )
Any body can give a hand !
The problem is JTAG function was blocked so that you can't access the chip with these pins. The only way is use parallel programmer to read back if the chip is not protected. Chip vendor did not release the algorithm of parallel programming, so you have to use commercial programmer.
you are completely right ; the only way is to use a commercial programmer for parallel programming / reading the chip..
Now after reading the file I tried to reload the pof file to the M@X Plus to use the JTAG port to program the new one ; the problem is that it can't recognize the file format ; although it's a pof file , but it seems that the programmer adds some headers to the file or some thing like this ..
Does any body tried to remove these headers done by Commercial programmers ..
I use Hi-L0 systems programmer !
I had the problem with BB and EPM7...
The problem was solved by setting the capacitor 100pF between TDI and GND.
Sorry, don't remember exactly - may be it was TDO.
