icfb version: IC5141USR2 sub version 5.10.41_USR2.19.52
Problem:Cannot view the transient data while simulation is run in IC5141USR2
Description:
Whenever I try to plot a transient data while simulation is running it gives me the following error ( and this happens to all the nodes in my circuit)
*Warning* Wave1 is not a waveform object that can be displayed and will be turned OFF automatically
expr: "VT(\"/OUT\")"
Once simulation is over I can plot the above transient data.
I've tried in both AWD and Wavescan and both cannot plot data while the simulation is runnig.
As an Example one can try runnig transient analysis of a simple RC circuit. Clock the input with high frequency pulse and run it for a long time.
While the simulation is running try to plot transient on input or output node. In my case I cannot access the data. I can only view the transient data after the simulation is complete.
Re: problem using transient simulation in IC5141USR2 using F
Try the Unix-command "sync" in a shell/terminal.
Maybe you need root permissions in this shell, depending on your installation.
It helps sometimes, unfortunately not always.
I'm currently investigating this problem.
