Problem using "From Workspace" Block in Simulink??
Luckybuilding
Member level 1
Hi, all
I have problem on using "From Workspace" Block of Matlab simulink.
When I use it in a model file. it gives me error.
I want to import an array of signal data ( in time domain) to a model.
Can anyone help me using this block of simulink?
Please, give me a sample model using this block if it is possible.
Thanks
Hi
There can be many types of problems you may face trying to use "From Workspace", I will try to list some:
1. Does the variable exist in the workspace?
2. The size of the variable suits the rest of the model?
3. Are you considering the right sample time?
Better read what the error message says when trying to run your model and work on it
cheers
Sal
Re: Problem using "From Workspace" Block in Simuli
Sal said:
Hi
cheers
Sal
Yeah, I think all are correct. But, I think a sample file may help me better.
Have you a sample model using the block??
Thanks
When I want to import a signal name, MATLAB gives me a dimension error.
I have tried to solve it. But,....
Thanks
this one worked for me..
