aec isp
I have downloaded the AEC ISP v3.0 program and build the cable, but every time i try to program my AT89S52 i got the following error message:
Error while programming Flash memory
Verify Flash memory
Flash byte error in address 0000
My hope is that any of you had the same error and in anyway can help me.
Thanks a lot
mcoster :?:
Details:
I am using windows ME and did not twist the cable (a line and a ground wire ).
I checked the reset status and i noticed it never got high so i add 10kohm pullup resistors.
But it still doens´t work.
My AT89S52 is rather new (more or less 50 write-erase cycles
