Register Log in
problem simulate near field in MWS CST
zhendian88
Newbie level 2
when i i want to simulate near field in MWS CST,i run the transient solver, it said ''The monitor 'e-field(f=10;z=10)'is outside simulation bounds and will be ignored.'' how can i change the simulation bounds?
shahid78
Full Member level 5
hi
i think you need to make sure your near field monitor is inside the simulation domain specified by you using boundary conditions
you can manually add space or use open(add space) boundary condition to resolve this problem
i hope this helps
regards
    zhendian88
zhendian88
Newbie level 2
thx unfortunately i already choose the open (add space),bt it still doesnt work .the boundary can not include the e field at 10cm far away.if i change the meshline to 40 it said this software can only allow 3000 mesh. can someone help me ???how to do it when i want to add a 10cm far away e field to simulate .plz
shahid78
Full Member level 5
hi there
well if i am not wrong you are simulation frequency is 10GHz and you are putting your e field monitor at 10cm which is about 3 * lambda away from your structure
so i dont know why u are saying your are measuing near field?
its definitely farfield
also it seems you are using educational version of software thats why number of mesh cells are limited.
i hope this helps
regards
Toggle Sidebar
