problem regardind DS1307 I2C RTC Code
jay_3189
Banned
Full Member level 1
Ahmedabad
I am using 89C51 controller with DS1307 RTC I2C and there I want to automate port 2 pins using RTC. but before that I am just trying to display time in hyper terminal. but there I get garbage values with below code in c.
so please any one can help me to solve that.
#include <stdio.h>
#include<reg51.h>
void DS1307_Init();
void DS1307_SetTime(unsigned char hh, unsigned char mm, unsigned char ss);
void DS1307_GetTime(unsigned char *h_ptr,unsigned char *m_ptr,unsigned char *s_ptr);
void DS1307_Write(unsigned char dat);
unsigned char DS1307_Read();
void I2C_Clock(void);
void I2C_Start();
void I2C_Stop(void);
void I2C_Write(unsigned char dat);
unsigned char I2C_Read(void);
void I2C_Ack();
void I2C_NoAck();
void delay_us(unsigned int us_count);
void serial_init(void);
int dec_to_bcd(int dec);
int bcd_to_dec(int bcd);
sbit SCL=P2^4; //SCL Connected to P2.4
sbit SDA=P2^5; //SDA Connected to P2.5
#define DS1307_ID 0xD0		// DS1307 ID
#define SEC_ADDRESS	0x00	// Address to access Ds1307 SEC register
#define DATE_ADDRESS 0x04	// Address to access Ds1307 DATE register
#define CONTROL 0x07		// Address to access Ds1307 CONTROL register
void main(void)
		DS1307_Init();
	   DS1307_SetTime(10, 55, 15);
		serial_init();
		while(1)
			  DS1307_GetTime(0x02, 0x01, 0x00);//Address to access Hour,Min,Sec
				delay_us(5000);
					DS1307 RTC
/*This function is used to initialize the Ds1307 RTC.
Ds1307 ic is enabled by sending the DS1307 id on the I2C bus.
After selecting DS1307, write 0x00 into Control register of Ds1307*/
void DS1307_Init()
	I2C_Start();	// Start I2C communication
	DS1307_Write(DS1307_ID); // Connect to DS1307 by sending its ID on I2c Bus
	DS1307_Write(CONTROL); // Select the Ds1307 ControlRegister to configure Ds1307
	DS1307_Write(0x00);	// Write 0x00 to Control register to disable SQW-Out
	I2C_Stop();	// Stop I2C communication after initilizing DS1307
/*This function is used to set Time(hh,mm,ss) into the Ds1307 RTC.
After selecting DS1307, select the RAM address 0x00 to point to sec Initilze Sec, MIN, Hour one after the other.
Stop the I2c communication.*/
	DS1307_Write(DS1307_ID); // connect to DS1307 by sending its ID on I2c Bus
	DS1307_Write(SEC_ADDRESS); // Select the SEC RAM address
	ss = dec_to_bcd(ss);
	mm = dec_to_bcd(mm);
	hh = dec_to_bcd(hh);
   	DS1307_Write(ss);	// Write sec on RAM address	00H
	DS1307_Write(mm);	// Write min on RAM address	01H
	DS1307_Write(hh);	// Write hour on RAM address 02H
	I2C_Stop();	// Stop I2C communication after Setting the Time
/*This function is used to get the Time(hh,mm,ss) from Ds1307 RTC.
After selecting DS1307, select the RAM address 0x00 to point to sec Get Sec, MIN, Hour one after the other.
	DS1307_Write(SEC_ADDRESS);	// Request Sec RAM address at 00H
	I2C_Stop();	// Stop I2C communication after selecting Sec Register
	DS1307_Write(0xD1);	// connect to DS1307( under Read mode) by sending its ID on I2c Bus
*s_ptr = DS1307_Read();  I2C_Ack();	// read second and return Positive ACK
*m_ptr = DS1307_Read();  I2C_Ack();	// read minute and return Positive ACK
*h_ptr = DS1307_Read();  I2C_NoAck();   // read hour and return Negative/No ACK
*s_ptr = bcd_to_dec(*s_ptr);
*m_ptr = bcd_to_dec(*m_ptr);
*h_ptr = bcd_to_dec(*h_ptr);
printf("Time is in ss:mm:hh =  %p:%p:%p\n", *s_ptr, *m_ptr, *h_ptr);
I2C_Stop();	// Stop I2C communication after reading the Time
/*This function is used to write a byte of data into Ds1307 RTC.
This function calls I2C_write function to perform the same*/
	I2C_Write(dat); // Connect to DS1307 by sending its ID on I2c Bus
	I2C_Clock();
/*This function is used to read a byte of data from Ds1307 RTC.
This function calls I2C_Read function to perform the same*/
	unsigned char dat;
	dat = I2C_Read(); // Connect to DS1307 by sending its ID on I2c Bus
	return(dat);
					I2C
/*This function is used to generate a clock pulse on SCL line.*/
	delay_us(1);
	SCL = 1;	// Wait for Some time and Pull the SCL line High
	delay_us(1);	// Wait for Some time
	SCL = 0;	// Pull back the SCL line low to Generate a clock pulse
/*This function is used to generate I2C Start Condition.
Start Condition: SDA goes low when SCL is High.*/
void I2C_Start()
	SCL = 0;	// Pull SCL low
	SDA = 1;	// Pull SDA High
	delay_us(1);
	SCL = 1;	//Pull SCL high
	delay_us(1);
	SDA = 0;	//Now Pull SDA LOW, to generate the Start Condition
	delay_us(1);
	SCL = 0;	//Finally Clear the SCL to complete the cycle
/*Stop Condition: SDA goes High when SCL is High.
SCL  __-----------
SDA  ______------*/
void I2C_Stop(void)
	delay_us(1);
	SDA = 0;	// Pull SDA  low
	delay_us(1);
	SCL = 1;	// Pull SCL High
	delay_us(1);
	SDA = 1;	// Now Pull SDA High, to generate the Stop Condition
/*This function is used to send a byte on SDA line using I2C protocol
8bit data is sent bit-by-bit on each clock cycle. MSB(bit) is sent first and LSB(bit) is sent at last.
Data is sent when SCL is low.*/
	unsigned char i;
	for(i=0;i<8;i++)	// loop 8 times to send 1-byte of data
	 	SDA = dat & 0x80;	// Send Bit by Bit on SDA line
		I2C_Clock();	// Generate Clock at SCL
		dat = dat<<1;
	SDA = 1;	// Set SDA at last
/*This fun is used to receive a byte on SDA line using I2C protocol.
8bit data is received bit-by-bit each clock and finally packed into Byte.
MSB(bit) is received first and LSB(bit) is received at last.*/
	unsigned char i, dat=0x00;
	SDA=1;	//Make SDA as I/P
	for(i=0;i<8;i++)		// loop 8times to read 1-byte of data
		delay_us(1);
		delay_us(1);
		dat = dat<<1;		//dat is Shifted each time and
		dat = dat | SDA;	//ORed with the received bit to pack into byte
		SCL = 0;			// Clear SCL to complete the Clock
	return dat;		// Finally return the received Byte*
/*This function is used to generate a the Positive ACK
pulse on SDA after receiving a byte.*/
void I2C_Ack()
	SDA = 0; 		//Pull SDA low to indicate Positive ACK
	I2C_Clock(); 	//Generate the Clock
	SDA = 1;		// Pull SDA back to High(IDLE state)
/*This function is used to generate a the Negative/NO ACK
pulse on SDA after receiving all bytes.*/
void I2C_NoAck()
	SDA = 1;		//Pull SDA high to indicate Negative/NO ACK
	I2C_Clock();	// Generate the Clock
	SCL = 1;		// Set SCL
					Delay
/*It genarates a approximate delay of 10us for each count,
if 5000 is passed as the argument then it generates a delay of apprx 50ms.*/
	while(us_count!=0)
		us_count--;
//Setup the serial port for 9600 baud at 11.0592MHz.
    SCON  = 0x50;               /* SCON: mode 1, 8-bit UART, enable rcvr         */
    TMOD |= 0x20;               /* TMOD: timer 1, mode 2, 8-bit reload           */
    TH1   = 0xFD;               /* TH1:  reload value for 9600 baud @ 11.0592MHz */
    TR1   = 1;                  /* TR1:  timer 1 run                             */
    TI    = 1;                  /* TI:   set TI to send first char of UART       */
 /*Decimal to BCD and Viceversa	*/
  		return ((dec/10)<<4) + (dec%10);
  		return ((bcd>>4)*10) + (bcd%16);
How about this line?
You are trying to print the pointer address since you are using %p format, but you passed the value.
I think you should use %d:%d:%d
ok I have change that to %d but still I am not getting proper timing but just getting 1:0:0 continuously.
hello,
Try to pass values parameters instead of pointers parameters..inside this function.
or if you want to keep use of pointer, declare pointers and initialize them.
My opinion is to use global variables.
same problem as in https://www.edaboard.com/threads/305029/
see zip attached..
