problem on compensation of a LDO?
ken_cn
Member level 2
Hi, all
I am designing a LDO. But when I simulated the open loop gain and phase, I found that the dc gain, unity gain frequency and phase margin are different in different loading condition.
How can I deal with it? Could you give me some suggestions?
Thank you!
Ken
2007/08/0.6
paley
Member level 4
yes, dc gain, unity gain frequency and phase margin are different in different loading condition.
because the load res will changed the output pole,and the ESR will add a zero,if your regulator have a large output cap,you must simulation the condition of max output current
szekit
Member level 5
Hong Kong
if your load is the second pole, worst case stability is at min output current and max output cap.
iamxo
Full Member level 4
Southeast Asia
i think you need to compensate your LDO to insure your LDO will be stable under all load condition!
good luck.
edwintsu
Member level 4
China
Ken, u can refer to the below patent.
B/R
Edwin
txdydhr
Newbie level 2
hi, szekit! u say worst case stability is at min output current and max output cap,
why the worst case stability is at these case? could u plz give a detailed commentate, thanks!
liuyonggen_1
Full Member level 4
put the dominant pole at the output, and consider the worst case, everything is OK
lokay
But it's hard to do that? How can you achieve?
