Problem Installing UBUNTU .
vamsicool
Newbie level 1
Chennai
i'm using toshiba l750 ,laptop , with 1Gb graphic card . with Win7 . when i'm installing ubuntu inside the windows it worked but it looklike low graphic version and effects within the Operating system are disabled . Please help me with this problem
skogsjanne
Full Member level 3
And the problem is? Please try to be a bit clearer in your description of the problem.
vinodstanur
Advanced Member level 3
Kerala (INDIA)
Which version of ubuntu? Ones I have the same problem. Then I tried ubuntu 11.04 and above. That worked fine ,,,
---------- Post added at 21:58 ---------- Previous post was at 21:57 ----------
Also, did you checked if you can change the screen resolution settings?
