rogger123
linux ixl file run
Hi
I am trying to install ic_flow v2004.2 on RH9.
I have followed the instructions from "icflow_webinst.pdf"
everything goes fine, it even installs all the packages but when it is arnd 96% complete it just stops and doesn't go any further nor does it give any error message in the log file... below is the portion of the log file where it gets stuck
Product: Schematic Generator_IC Ap SW, load complete.
Writing product information to /usr/Mentor/_contents.
Linking MGC tree
link_tree: unable to determine machine type of /
defaulting to Intel x86 Linux
Checking links in MGC tree at /usr/Mentor
Linking master MGC tree at /usr/Mentor
Linking top-level dirs in /usr/Mentor/pkgs
Updating /usr/Mentor/toolbox
Linking top-level dirs in /usr/Mentor/shared/pkgs
Executing package post installation scripts.
/usr/Mentor/pkgs/mgls.ixl/post_install_script
/usr/Mentor/pkgs/olh.ixl/post_install_script
Creating index for a Library in /usr/Mentor/shared/htmldocs/wwhelp
it just stops at the last line "Creating index..........."
Do i need to change the mode of the install.<vco> file before i untar it to get the install8 folder???
I tried canceling the installation at 96% and set the environment variables and tried running but unfortunately the ../registry/fonts directory is empty and none of the applications run.
I also get the following error when I run lmgrd
incorrectly built binary which accesses errno or h_errno directly. Needs to be fixed.
Can someone please help me
regards
rogger
Hi
Linking MGC tree
regards
rogger
