[SOLVED] problem in writing FLASH memory of AVR via ISP
vinodstanur
Advanced Member level 3
Kerala (INDIA)
I am trying to read and write FLASH and EEPROM of an AVR (atmega8) via ISP.
I had programmed a PIC16F877A which accepts 8 bit data from UART (hyperterminal) and send it to AVR via SPI at reset zero...
I have successfully enabled the ISP mode by sending
cmd(0xac, 0x53, 0, 0); also verified the return byte.
Now I can write and read back the EEPROM without any problem..
for example,
cmd(c0,00,11,AB) writes AB at 11 of eeprom
Now I could read it by
cmd(a0,00,11,xx)
NO PROBLEM UPTO THIS...
Now,
when I am tying to write and read the FLASH, I am always gettign 0xff while reading,,,
I used command 60,68 to write and 20,28 to read (lower byte and higher byte respectively)
But ALWAYS READING 0XFF even if I modify it...
what may be the problem ?
I haven't faced the ISP challenge yet, but I found this reference from ATMEL:
http://www.atmel.com/dyn/resources/prod_documents/doc0943.pdf
page 7:
The Flash is programmed one page at a time.
I conudn't understand how we write flash by one page at a time..
More over, I think it is not explained in data sheet and the ISP application note..
Yes you are right in this reference it is not explained. There is a possibility that the page write proccess is MCU dependent. Maybe you could take a look at some AVR datasheets and find that out.
Just an assumption... :smile:
I just looked into the USBASP source code (isp.c) but still I couldn't makeout....
I can write and read EEPROM but not FLASH...
