Normally all the triacs are commoned to the neutral line with the loads commoned to the live with the triacs switching pulling the ends of the loads down to neutral.
Frank
In your point of view live are directly connected to the one end of the Load,That way neutral can be bypassed via Triac .But line directly to the load and neutral via switch is not the proper method for wiring .Line are bypassed via switch for safety purpose.
What about moving the snubber circuits (away) from the load to the triac.
Klaus
Measuring a high impedance voltage is meaningless.
Klaus
A triac switch won't be recognized as safety switch in any case, in so far the question isn't actually relevant. The circuit behind the triac must be considered as hazardous contact voltage, no matter if the triac is on or off.Does high impedance voltage affect,when any one touch it?.
