Problem in systemC for Visual studio 2008
Tom2
Full Member level 5
I tried to install systemC at Visual studio 2008.
The first step for this is to download SystemC 2.2.0 (from www.systemc.org) and then open \systemc-2.2.0\msvc71\SystemC\SystemC.vcproj
(using visual studio 2008)
After this i have to bult the project and as a result , SystemC.lib it suppost create.
The main problem is that when i built it, a lot of errors are exist.
Is anyone who know , how to fix this?????????????????????
did you add the systemC.lib in "additional dependencies". check the following document to configure it
Right-click on project name, then go to “Properties → Configuration Properties → Linker → Input” and in the right panel, add to “Additional Dependencies” the SystemC Library you created, namely “systemc.lib”
regards
bassa
Dear bassa,
I use this document too.
The main problem is:
When i try to built the projetc (step 5),
the systemC.lib is not created.
How to fix this????
Hi Tom2,
I am using Visual Studio 2005 professional edition with SP1 and systemC.lib created successfully. No errors reported
1>Creating library...
1>Build log was saved at "file://c:\systemc-2.2.0\msvc71\SystemC\Debug\BuildLog.htm"
1>SystemC - 0 error(s), 231 warning(s)
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
The errors may be due to missing header files, or missing libraries.
can you attach the build output as file then I'll check the errors.
If you need systemC.lib I can attach the created systemC.lib for your reference. but file size is 20.5MB
regards
bassa
Dear bassa,
i tried to use visual studio 2005 and the systemc.lib file it was created succesful.
Now when i tried to compile a project in systemc i see the error LNK2005.
Did you had any similar problem in your project?
Hane you got any sujestions, how to fix it?
Tom2 said:
Dear bassa,
I opened fft_flpt sample project in C:\systemc-2.2.0\examples\sysc\fft\fft_flpt directory and build it then it succeed.
1>Linking...
1>Embedding manifest...
1>Project : warning PRJ0018 : The following environment variables were not found:
1>$(SYSTEMC)
1>Build log was saved at "file://c:\systemc-2.2.0\examples\sysc\fft\fft_flpt\Debug\BuildLog.htm"
1>fft_flpt - 0 error(s), 12 warning(s)
========== Rebuild All: 1 succeeded, 0 failed, 0 skipped ==========
check general comments on "error LNK2005 "
If you can attache the output file then I'll check it
good luck!
bassa
oh , I have the Same problem , when i build fft_flpt example these horrible message come
1>------ Build started: Project: fft_flpt, Configuration: Debug Win32 ------
1>Linking...
1>systemc.lib(sc_simcontext.obj) : error LNK2019: unresolved external symbol "class sc_core::sc_report * __cdecl sc_core::sc_handle_exception(void)" (?sc_handle_exception@sc_core@@YAPAVsc_report@1@XZ) referenced in function __catch$?run_process@sc_method_process@sc_core@@IAE_NXZ$0
1>systemc.lib(sc_thread_process.obj) : error LNK2001: unresolved external symbol "class sc_core::sc_report * __cdecl sc_core::sc_handle_exception(void)" (?sc_handle_exception@sc_core@@YAPAVsc_report@1@XZ)
1>systemc.lib(sc_main_main.obj) : error LNK2001: unresolved external symbol "class sc_core::sc_report * __cdecl sc_core::sc_handle_exception(void)" (?sc_handle_exception@sc_core@@YAPAVsc_report@1@XZ)
1>systemc.lib(sc_simcontext.obj) : error LNK2019: unresolved external symbol "protected: void __thiscall sc_core::sc_unwind_exception::clear(void)const " (?clear@sc_unwind_exception@sc_core@@IBEXXZ) referenced in function __catch$?run_process@sc_method_process@sc_core@@IAE_NXZ$0
1>systemc.lib(sc_thread_process.obj) : error LNK2001: unresolved external symbol "protected: void __thiscall sc_core::sc_unwind_exception::clear(void)const " (?clear@sc_unwind_exception@sc_core@@IBEXXZ)
1>systemc.lib(sc_simcontext.obj) : error LNK2019: unresolved external symbol "protected: __thiscall sc_core::sc_unwind_exception::sc_unwind_exception(class sc_core::sc_process_b *,bool)" (??0sc_unwind_exception@sc_core@@IAE@PAVsc_process_b@1@_N@Z) referenced in function "protected: void __thiscall sc_core::sc_thread_process::suspend_me(void)" (?suspend_me@sc_thread_process@sc_core@@IAEXXZ)
1>systemc.lib(sc_wait.obj) : error LNK2001: unresolved external symbol "protected: __thiscall sc_core::sc_unwind_exception::sc_unwind_exception(class sc_core::sc_process_b *,bool)" (??0sc_unwind_exception@sc_core@@IAE@PAVsc_process_b@1@_N@Z)
1>systemc.lib(sc_thread_process.obj) : error LNK2001: unresolved external symbol "protected: __thiscall sc_core::sc_unwind_exception::sc_unwind_exception(class sc_core::sc_process_b *,bool)" (??0sc_unwind_exception@sc_core@@IAE@PAVsc_process_b@1@_N@Z)
1>systemc.lib(sc_method_process.obj) : error LNK2001: unresolved external symbol "protected: __thiscall sc_core::sc_unwind_exception::sc_unwind_exception(class sc_core::sc_process_b *,bool)" (??0sc_unwind_exception@sc_core@@IAE@PAVsc_process_b@1@_N@Z)
1>systemc.lib(sc_simcontext.obj) : error LNK2001: unresolved external symbol "public: virtual __thiscall sc_core::sc_unwind_exception::~sc_unwind_exception(void)" (??1sc_unwind_exception@sc_core@@UAE@XZ)
1>systemc.lib(sc_wait.obj) : error LNK2001: unresolved external symbol "public: virtual __thiscall sc_core::sc_unwind_exception::~sc_unwind_exception(void)" (??1sc_unwind_exception@sc_core@@UAE@XZ)
1>systemc.lib(sc_thread_process.obj) : error LNK2001: unresolved external symbol "public: virtual __thiscall sc_core::sc_unwind_exception::~sc_unwind_exception(void)" (??1sc_unwind_exception@sc_core@@UAE@XZ)
1>systemc.lib(sc_method_process.obj) : error LNK2001: unresolved external symbol "public: virtual __thiscall sc_core::sc_unwind_exception::~sc_unwind_exception(void)" (??1sc_unwind_exception@sc_core@@UAE@XZ)
1>systemc.lib(sc_simcontext.obj) : error LNK2001: unresolved external symbol "public: virtual char const * __thiscall sc_core::sc_unwind_exception::what(void)const " (?what@sc_unwind_exception@sc_core@@UBEPBDXZ)
1>systemc.lib(sc_wait.obj) : error LNK2001: unresolved external symbol "public: virtual char const * __thiscall sc_core::sc_unwind_exception::what(void)const " (?what@sc_unwind_exception@sc_core@@UBEPBDXZ)
1>systemc.lib(sc_thread_process.obj) : error LNK2001: unresolved external symbol "public: virtual char const * __thiscall sc_core::sc_unwind_exception::what(void)const " (?what@sc_unwind_exception@sc_core@@UBEPBDXZ)
1>systemc.lib(sc_method_process.obj) : error LNK2019: unresolved external symbol "public: virtual char const * __thiscall sc_core::sc_unwind_exception::what(void)const " (?what@sc_unwind_exception@sc_core@@UBEPBDXZ) referenced in function "public: __thiscall std::_Ranit<class sc_core::sc_object *,int,class sc_core::sc_object * const *,class sc_core::sc_object * const &>::_Ranit<class sc_core::sc_object *,int,class sc_core::sc_object * const *,class sc_core::sc_object * const &>(void)" (??0?$_Ranit@PAVsc_object@sc_core@@HPBQAV12@ABQAV12@@std@@QAE@XZ)
1>Debug/fft_flpt.exe : fatal error LNK1120: 5 unresolved externals
1>Build log was saved at "file://f:\systemc-2.3.0_pub_rev_20111121\examples\sysc\fft\fft_flpt\Debug\BuildLog.htm"
1>fft_flpt - 18 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
