problem in simulation with cadence Spectre
jonneylu
Member level 1
cadence problems encountered during simulation
When i use spectre to simulation in Cadence Analog Artist,what on CIW is
"start simulator if needed....
....successful.
Problems encountered during simulation.
Use the Simulation->Output Log menu for more information. "
But this moment the "Output Log" option is dark, can't open it.
I dont know what cause it , please help me! Think you!
nxing
Advanced Member level 1
China
cadence spectre simulation output log menu
Do you really have the license to run spectre simulator?
haley_8
Junior Member level 2
cadence problem encountered during simulation
I actually have problems running spectre too. I know how to run hspice in Cadence, but can someone please tell me how to set up for spectre simulation? Thanks!
paji
Newbie level 6
I have problems running spectre too. But you can solve it by resetting the simulation condition and variable.good luck!
rob1012
Junior Member level 3
cadence problem during simulation log menu
probably you do not have license to run spectre simulation. Also, you could check log file in the simulation directory you specified in ADE.
zpb2k
Newbie level 5
I've seen this problem before. I don't believe it is license problem. Maybe you should consult your CAD people or restart Cadence.
