[SOLVED] problem in simulating the seven segment display on proteus
abhishekdixit
Full Member level 2
Full Member level 2
India
hi,
i want to make a digital clock, for which i have written my code on 8051 micro controller, now when i simulate my code on Proteus, it gives the error and not working properly. i am attaching my code and Proteus pic with this post. please help me..
#include<reg51.h>
 sbit dig_ctrl_4=P1^0;        //Declaring control pins of the seven segments
 sbit dig_ctrl_3=P1^1;
 sbit dig_ctrl_2=P1^2;
 sbit dig_ctrl_1=P1^3;
 unsigned char dig_disp=0;
 int min2;
 int min1;
 int sec2;
 int sec1;
 char digi_val[10]={0x40,0xF9,0x24,0x30,0x19,0x12,0x02,0xF8,0x00,0x10};
void delay()        //Function to provide a time delay of approx. 1 second. using Timer 1.
    int i;
    for(i=0;i<20;i++)
        TL1=0xFD;
         TH1=0x4B;
         TR1=1;
         while(TF1==0);
         TR1=0;
         TF1=0;
void display() interrupt 1        //Function to display the number using seven segmnet multiplexing. For more details refer seven segment multiplexing.
    TL0=0x36;        //Reloading Timer0
    TH0=0xf6;
    P2=0xFF;
    dig_ctrl_1 = dig_ctrl_3 = dig_ctrl_2 = dig_ctrl_4 = 0;
    dig_disp++;
    dig_disp=dig_disp%4;
    switch(dig_disp)
        case 0:
        P2=digi_val[sec1];
        dig_ctrl_1 = 1;
        break;
        case 1:
        P2=    digi_val[sec2];
        dig_ctrl_2 = 1;
        break;
        case 2:
        P2=    digi_val[min1];
        dig_ctrl_3 = 1;
        break;
        case 3:
        P2=    digi_val[min2];
        dig_ctrl_4 = 1;
        break;
void main()
    TMOD=0x11;        //Intialize Timer 0
    TL0=0x36;
    TH0=0xF6;
    IE=0x82;        // Enable Timer 0 interrupt
    TR0=1;        //Start Timer 0
    while(1)        //Start clock
          min2=min1=sec2=sec1=0;
          for(min2=0;min2<6;min2++)
               for(min1=0;min1<10;min1++)
                for(sec2=0;sec2<6;sec2++)
                     for(sec1=0;sec1<10;sec1++)
                        delay();
and proteus design
when i simulate this circuit, it gives a following error
Please help me
thank you,
with regards,
Abhishek Dixit
This is not a bug, just the simulator "overload" indicates.
My proposal (only in Proteus :wink: ):
- abandon the four emitter-follower drivers
- abandon the entire oscillator and reset circuit
If that does not enough, use the 7SEG-MPX4-CA device, instead of the separate 7seg displays.
