vspoojari
Newbie level 3
ade xl
I am trying to setup IC613 in my local UNIX account at my university.
Attached are the common environment setup files used by me. Following
are the steps that I use for invoking IC613:
1. Source the design_environment_613.csh from my 'home' folder
2. The 'cdsinit' file is located in the directory from which I start
the 'CIW'.
3. The 'cdsenv' and 'cdsplotinit' files are located in my home
directory.
The problem is that when I try to start ADE-XL or ADE-GXL from the
schematic editor, it throws up some strange error "*Error* eval:
undefined function - _SessionIlCmdWrapper". The complete warning and
error message is present in the CDS.log file below.
I am not sure whether there is some setup issue or not. Has anyone
faced this kind of error while working with IC613?
Any kind of inputs is highly appreciated.
---VP
________________________________________________________________________________________________
CDS.log file Contents
\o COPYRIGHT © 1992-2008 CADENCE DESIGN SYSTEMS INC. ALL RIGHTS
RESERVED.
\o © 1992-2008 UNIX SYSTEMS Laboratories INC.,
\o Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and
disclosure.
\o
\o RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\a hiResizeWindow(window(1) list(0:32 1280:976))
\r t
\o Loading geView.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading LVS.cxt
\o Loading layerProc.cxt
\o Loading xlUI.cxt
\o Loading auCore.cxt
\o Loading vhdl.cxt
\o Loading seismic.cxt
\o Loading ci.cxt
\o Loading ams.cxt
\o Bindkeys loaded x.
\p >
\o Loading gpdk180/libInit.il ...
\o Loading gpdk180/loadCxt.ile ... done!
\o Loading context 'gpdk180' from library 'gpdk180' ... done!
\o Loading context 'pdkUtils' from library 'gpdk180' ... done!
\o Loading gpdk180/.cdsenv ... done!
\o Loading gpdk180/display.drf ... done!
\o Loading gpdk180/libInitCustomExit.il ... Loading awv.cxt
\o Loading oasis.cxt
\o Loading analog.cxt
\o Loading asimenv.cxt
\o Loading spectrei.cxt
\o Loading hspiceD.cxt
\o Loading spectreinl.cxt
\o Loading UltraSim.cxt
\o Loading AMS.cxt
\o
\a (_axlInitMainWindow)
\o Loading adexl.cxt
\w *WARNING* artDLOpen: ¨úr s/cadence/IC613/IC613/tools/lib/
libsessionil.so
\w Cannot open shared library 'libsessionil'
\w *WARNING* artDLOpen: libXm.so.3: cannot open shared object file: No
such file or directory
\e *Error* eval: undefined function - _SessionIlCmdWrapper
\p >
\a hiiSetCurrentForm('axlIntroForm)
\r t
\a axlIntroForm->radioField->value= "Create New View"
\r "Create New View"
\a hiFormDone(axlIntroForm)
\r t
\p >
\a hiiSetCurrentForm('deNewForm)
\r t
\a hiFormDone(deNewForm)
\w *WARNING* A Skill error occurred in function
_axlWindowCreateTrigger
\e *Error* windowCreateTrigger for viewType (adexl) failed to create a
window!
\r t
\r nil
the 'CIW'.
directory.
---VP
RESERVED.
\o
disclosure.
\o
\r t
\o Loading LVS.cxt
\o Loading xlUI.cxt
\o Loading vhdl.cxt
\o Loading ci.cxt
\o Loading ams.cxt
\p >
\o Loading AMS.cxt
\o
libsessionil.so
\p >
\r t
\r t
\p >
\r t
window!
\r t
\r nil
