[SOLVED] problem in setting baud rate
ismbn
Full Member level 3
Mumbai. india
How To Convert ascii to decimal To Send via USART For AT MEGA 32...
Hi all...
I am Using AVR Studio 6 for compiling...
here is my code i want to count the pulses from the external source and transmit it though USART. I have connected that(external pulse) to the External interrupt & incrementing it when interrupt hits, Also able to transmit it though USART but the problem is when i am checking it on hyper terminal the ascii characters are coming... like this "☺☻♥♣♣♠•◘○◙♂...."
What to do if i want to send it in decimal values like if the ISR hits 10 time it should send value "10"
not " ◙ "....
Is it Possible to make it like this.....
my
#include <avr/io.h>
#include <avr/interrupt.h>
#include "dbits/uart.h"
#include "dbits/uart.c"
#include <math.h>
#define F_CPU 16000000l
int make;
int a=0,b=0,i=0;
void getpar()
	uart_init(16);
	sei();
	uart_putc('w');
	uart_flush ();
	while(uart_available()==0);
	make= uart_getc();
void ex_intr()
	MCUCR |= (1<<ISC10)|(1<<ISC11)|(1<<ISC00)|(1<<ISC01);
	GICR |= (1<<INT0);
	sei();
int main(void)
	DDRA= 0xff;
	ex_intr();
	getpar();
	uart_putc('s');
    while(1)
ISR(INT0_vect)
	a++;
	PORTA=i;
	uart_putc(a);
	i++;
Regards...
Ismail
Re: How To Convert ascii to decimal To Send via USART For AT MEGA 32...
Have you set the hyperterminal baud rate properly?
ismbn
Full Member level 3
Mumbai. india
@internetuser2k12
Thanks For the reply sir...
Yes i have set in right Sir alex guided me for that...
Ismail
https://www.edaboard.com/threads/265655/
By mistake i made the wrong title...
there for i made it correct... please look into this Sir internetuser2k12
Ismail
