dsp tms320lf2407a
Hi djolestojic,
Thanks for reply. I have taken care of PLL circuitry and also the capacitor values are correct for using 10 MHz freq from an external oscillator.
But i found that when i am running the program, the CLKOUT is getting default value(.5xFin), inspite of being chosing the bit 9-11 of SCSR1 rgister as 000. This means my program is not at all executed.
I have analyzed the hex file generated from the TI flash program serial utility from an out file (generated through CCS), that it shows entry point address lies in between text code section, is this could be a problem?
I have used settings as generate 'Absolute Executable' and COFF1 in CCS.
Can you put some light on this so that it can guide me rightly.
regards
Added after 7 minutes:
Hi djolestojic,
One more thing that i found apart from the above post is, RS pin is getting low pulses, which may be because the watchdog is resetting that is why DSP is getting reset and the program is not running at all.
But I have taken care of disabling Watchdog. Still it is getting reset, what could be the problem?
regard
