[SOLVED] problem in RS232 vhdl code
vishy71
Full Member level 2
Full Member level 2
Iran
www.korosh-life.blogfa.com
Hi.I am so sorry because of my poor English speaking!
I am trying to write a simple code in VHDL for RS232 to receive data through a wire as you know.here is my code!
something is wrong! please help me to solve this challenge!thanks :)
as you can see,bit_cnt pulsed twice!!!!!why? and number of "get" state must be 8 not 4!!!!
here is my code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity rcv is
	port(din,clk:in std_logic;dout:out std_logic_vector(7 downto 0);ready:out std_logic);
end entity;
architecture arch_rcv of rcv is
	type rcv_state is (idle,start,wt,plus,get,stop);
	signal curr_state,next_state:rcv_state;
	signal bit_cnt:unsigned(3 downto 0):="0000";
	signal clk_cnt:unsigned(15 downto 0):=x"0000";
	begin
	process(curr_state,din,clk)is
	  begin
		if(clk'event and clk='1') then
			curr_state<=next_state;
		elsif(din'event and din='0' and curr_state=idle)then
			next_state<=start;
		elsif(curr_state=idle)then
			bit_cnt<="0000";
			clk_cnt<=x"0000";
			ready<='1';
		elsif(curr_state=start)then
			ready<='0';
			if(clk_cnt=2600)then
				next_state<=wt;
				clk_cnt<=x"0000";
			else
				clk_cnt<=clk_cnt+1;
			end if;
		elsif(curr_state=wt)then
			if(clk_cnt=5200)then
				clk_cnt<=x"0000";
				next_state<=get;
			else
				clk_cnt<=clk_cnt+1;
			end if;
		elsif(curr_state=get)then
			if(bit_cnt=8)then
				next_state<=stop;
			else
				dout(to_integer(bit_cnt))<=din;
				bit_cnt<=bit_cnt+1;
				next_state<=wt;
			end if;
		elsif(curr_state=plus)then
		elsif(curr_state=stop)then
				next_state<=idle;
			else
				clk_cnt<=clk_cnt+1;
			end if;
		end if;
	end process;
end arch_rcv;
also I try to make new state with "plus" name to increase bit_cnt but when I do that,it increased twice!!! for example : bit_cnt<="0000" and after bit_cnt<=bit_cnt+1 it was "0010"!!!!!!
thanks.
This is not the correct template for a state machine. You need either two separate process: one for registering the state, and another for decoding the outputs and next state.
Or use a single clocked process.
You should not be using else-ifs with a clock. It will not compile.
thanks.let me try it :)
whats wrong!
it dose not fill dout!!!!
library ieee;
entity rcv is
end entity;
	signal curr_state,next_state:rcv_state:=idle;
	begin
	process(curr_state,din)is
	    begin
			bit_cnt<="0000";
			clk_cnt<=x"0000";
			if(din='0')then
				next_state<=start;
			end if;
			ready<='1';
			clk_cnt<=x"0000";
			ready<='0';
				next_state<=wt;
				clk_cnt<=x"0000";
			else
				clk_cnt<=clk_cnt+1;
			end if;
				clk_cnt<=x"0000";
				next_state<=get;
			else
				clk_cnt<=clk_cnt+1;
			end if;
			if(bit_cnt=8)then
				next_state<=stop;
			else
				bit_cnt<=bit_cnt+1;
				next_state<=wt;
			end if;
				next_state<=idle;
			else
				clk_cnt<=clk_cnt+1;
			end if;
		end if;
	end process;
	process(clk) is
		begin
		end if;
	end process;
end arch_rcv;
Severl problems.
You cannot put a counter in an asynchronous process.
And you need to assing all signals in ALL cases in the async process. You cannot have en empty if branch either.
I solve it.thanks.
library ieee;
entity rcv is
end entity;
	type rcv_state is (idle,start,get,wt,stop);
	signal clk_div_en,clk_div1,clk_div2:std_logic:='0';
	signal clk_cnt1,clk_cnt2:unsigned(15 downto 0):=x"0000";
	begin
	process(clk)is
		begin
		if(clk'event and clk='1')then
			if(clk_div_en='1')then
				if(clk_cnt1=2600)then
					clk_div1<=not clk_div1;
				else
					clk_cnt1<=clk_cnt1+1;
				end if;
				if(clk_cnt2=5200)then
					clk_div2<=not clk_div2;
					clk_cnt2<=x"0000";
				else
					clk_cnt2<=clk_cnt2+1;
				end if;
			elsif(clk_div_en='0')then
				clk_cnt2<=x"0000";
			end if;
		end if;
	end process;
	process(din,curr_state,clk_div1,clk_div2)is
		begin
			ready<='1';
			clk_div_en<='0';
			bit_cnt<="0000";
			if(din='0')then
				next_state<=start;
			end if;
			ready<='0';
			clk_div_en<='1';
			if(clk_div1='1')then
				next_state<=get;
			end if;
			if(clk_div2='1')then
				if(bit_cnt=8)then
					next_state<=stop;
				else
					bit_cnt<=bit_cnt+1;
					next_state<=wt;
				end if;
			end if;
			if(clk_div2='0')then
				next_state<=get;
			end if;
				next_state<=idle;
			end if;
		end if;
	end process;
end arch_rcv;
THis does not fix it. You still have a counter in the async process so you have signals missing from the sensitiivty list. This code will not work.
but it works :).you right but ISE will append missed signals to process ;-)
a have changed it but it was my first code for usart which works good.
