gmish27
Member level 1
here is my code that i have used to make a register for my basic computer:
Now when i am using this register as a top module to check the functioning of it like if provide an 'inc=1'b1' signal in the test bench, the output i.e 'odat' becomes high in the same clock cycle.
But when i interface this register to the control signals as if:
inc = control_signal[1];
the output 'odat' gets high in the next clock cycle. please tell why???
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 module register #(parameter n=2) ( input inc,we, input clr,clk, input [n-1:0] idat, output [n-1:0] odat ); reg [n-1:0] data; always@(posedge clk, posedge clr) if(clr) data <= 0; else if(inc) data <= data + 1; else if(we) data <= idat; assign odat = data; endmodule
