Problem in Ps/2 keyboard interface
xorgate
Newbie level 3
pune
Hi Friends,
I am new to FPGA i am trying to interface the ps/2 interface with my keyboard ,I can understand operation which occurs in the ps/2 interface , but i can't write the code by own for the same,i am using the spartan 3e board ,can any one help me to do this one, any good material or verilog code is needed,and how to put the state diagram for the ps/2 interface.
--Xorgate
Hi this is a code for reading PS/2 port on the Xess board:
-- This design accepts keystrokes from a PS/2 keyboard and displays a numeral on
-- the 7-segment display of the XSA Board if one of the keys 0-9 is pressed.
-- Otherwise, it displays an E.
library IEEE, unisim;
use IEEE.std_logic_1164.all;
use IEEE.NUMERIC_STD.all;
use unisim.vcomponents.all;
use work.ps2_kbd_pckg.all;
entity test_kbd is
  generic(
    FREQ     :     natural := 100_000   -- frequency of main clock (KHz)
  port(
    clk      : in  std_logic;           -- main clock
    ps2_clk  : in  std_logic;           -- keyboard clock
    ps2_data : in  std_logic;           -- keyboard data
    s        : out std_logic_vector(6 downto 0)  -- LED display
end entity;
architecture arch of test_kbd is
  constant YES : std_logic := '1';
  constant NO  : std_logic := '0';
  signal scancode  : std_logic_vector(7 downto 0);  -- scancode from keyboard
  signal rdy       : std_logic;         -- indicates when scancode is available
  signal s_x       : std_logic_vector(6 downto 0);  -- next state of LED segments
  signal kbd_error : std_logic;         -- error receiving scancode from keyboard
  -- LED segment activation patterns for various numbers and letters
  constant DIG_1    : std_logic_vector(6 downto 0) := "0010010";
  constant DIG_2    : std_logic_vector(6 downto 0) := "1011101";
  constant DIG_3    : std_logic_vector(6 downto 0) := "1011011";
  constant DIG_4    : std_logic_vector(6 downto 0) := "0111010";
  constant DIG_5    : std_logic_vector(6 downto 0) := "1101011";
  constant DIG_6    : std_logic_vector(6 downto 0) := "1101111";
  constant DIG_7    : std_logic_vector(6 downto 0) := "1010010";
  constant DIG_8    : std_logic_vector(6 downto 0) := "1111111";
  constant DIG_9    : std_logic_vector(6 downto 0) := "1111011";
  constant DIG_0    : std_logic_vector(6 downto 0) := "1110111";
  constant LETTER_E : std_logic_vector(6 downto 0) := "1101101";
begin
  u0 : ps2_kbd
    generic map(
      FREQ     => FREQ
    port map(
      clk      => clk,                  -- clock for the keyboard interface
      rst      => kbd_error,            -- reset the keyboard intfc whenever there is an error receiving a scancode
      ps2_clk  => ps2_clk,              -- clock from the keyboard
      ps2_data => ps2_data,             -- serial data from the keyboard (valid on falling edge of ps2_clk)
      scancode => scancode,             -- the scancode received from the keyboard
      rdy      => rdy,                  -- indicates when a scancode from the keyboard is available
      error    => kbd_error             -- indicates an error in receiving a scancode from the keyboard
  -- this maps the scancode received from the keyboard into a pattern on the 7-segment display
  s_x <= DIG_1 when scancode = "00010110" else
         DIG_2 when scancode = "00011110" else
         DIG_3 when scancode = "00100110" else
         DIG_4 when scancode = "00100101" else
         DIG_5 when scancode = "00101110" else
         DIG_6 when scancode = "00110110" else
         DIG_7 when scancode = "00111101" else
         DIG_8 when scancode = "00111110" else
         DIG_9 when scancode = "01000110" else
         DIG_0 when scancode = "01000101" else
         LETTER_E;
  -- update the LED display
  process(clk)
  begin
    if rising_edge(clk) then
      if rdy = YES then
        s <= s_x;                       -- update the display each time a scancode is received
      end if;
    end if;
  end process;
end architecture;
Hope you find it useful! You can find more examples on their web site:
https://www.xess.com/design_examples.php
Best regards,
/Farhad Abdolian
