problem in micro c, plz hlp
peter002
Member level 3
Hindusthaan
hello brothers, i ve just started working in microc pro, the problem is that wen i wrote a test code for the first time , it worked fine but after that wen i ever i m trying to write another code the software always shows error that main indentifier is redefined...
i dont know what the probem is... i hav tried al i could, ike i ve deleted a older projects and tried new project with diff names, i ve even kept the main c file empty only containing void main ad its braces and after saving it and compiling itshows same error again, plz hp me..
thanx in advance
look in the other files in the project, you must have another main() defined in one of them
you should only have one main() function defined in a project
brother i did not added more than one file, there is only file added in a project..there arent two files..
