Problem in I2C EEPROM EXECUTION..
SHANTHI5555
Newbie level 3
Newbie level 3
hi
i am working on a real time project using I2C EEPROM AT24C512.
For EEPROM AT24C512 testing i wrote code in QuatusII - Nios.
and it is working fine when it is in sequence commands.
then i tried it as functions. and i wrote initialize,write, and read functions. And these functions are called in main functions. now i am not getting correct output.
the code is copied below
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
#include "system.h"
#include "stdio.h"
#include "io.h"
unsigned int initiate();
unsigned int i2c_write(unsigned int ,unsigned int );
unsigned int i2c_read(unsigned int );
void Delay(unsigned int,unsigned int);
#define I2C_PRER0 0x00
#define I2C_PRER1 0x04
#define I2C_CTR 0x08
#define I2C_TXR 0x0C
#define I2C_RXR 0x0C
#define I2C_CR 0x10
#define I2C_SR 0x10
#define PRER_0 0x09
#define PRER_1 0x00
#define SLAVE_ADDR_WR 0XA0
#define SLAVE_ADDR_RD 0XA1
unsigned int TIP[8];
unsigned int out_data;
unsigned int i;
int main()
    unsigned int i;
    unsigned int in_data=0XBB;
    unsigned int mem_addr=0x01;
    initiate();
    for(i=0x00;i<=0X10;i++)
        i2c_write(mem_addr,0xFF);
        i2c_write(mem_addr,in_data);
        i2c_read(mem_addr);
        in_data-in_data+0x01;
return 0;
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_PRER0,0x09);
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_PRER1,0x00);
    IOWR_32DIRECT(WB_CYC_I_BASE,I2C_CTR,0x01);
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_CTR,0x80);
    return 0;
unsigned int i2c_write(unsigned int mem_addr,unsigned int in_data)
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_TXR,0XA0);
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_CR,0X90);
    TIP[8]= (IORD_32DIRECT(I2C_PIO_HW_0_BASE,I2C_SR)&(0xFF)) ;
    while(TIP[1] != 0)
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_TXR,mem_addr);
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_CR,0X10);
    TIP[8]= (IORD_32DIRECT(I2C_PIO_HW_0_BASE,I2C_SR)&(0xFF));
    while(TIP[1] != 0)
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_TXR,in_data);
    printf("\n mem_addr %X , in_data %X",mem_addr,in_data);
    while(TIP[1] != 0)
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_CR,0X50);
    return 0;
unsigned int i2c_read(unsigned int mem_addr)
    while(TIP[1] != 0)
    while(TIP[1] != 0)
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_TXR,0XA1);
    TIP[8]= (IORD_32DIRECT(I2C_PIO_HW_0_BASE,I2C_SR)&(0XFF) );
    while(TIP[1] != 0)
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_CR,0X20);
    Delay(1,1);
    TIP[8]= (IORD_32DIRECT(I2C_PIO_HW_0_BASE,I2C_SR)&(0xFF) );
    printf("\n out_data = %X",IORD_32DIRECT(I2C_PIO_HW_0_BASE,I2C_RXR));
    while(TIP[1] != 0)
    IOWR_32DIRECT(I2C_PIO_HW_0_BASE,I2C_CR,0X28);
    return 0;
void Delay(unsigned int a,unsigned int b)
 unsigned int x,y;
 for(x=0;x<=a;x++)
     for(y=0;y<=b;y++)
i don't know that what is the problem in that. please tell about this.
thank you...
I don't see any references to EEPROM I2C addresses in your code, thus I believe it doesn't actually access it.
There are other points like generating correct EEPROM commands with address field, and required ACK polling after write actions. But that's next.
SLAVE_ADDR_WR this is EEPROM I2C address write address,
SLAVE_ADDR_RD this is EEPROM I2C address read address defined globally because its a fixed adrresses.
that TIP is Reading of ACK and TIP bit of SR register, its a ack polling only right.
O.K., you have repeated SLAVE_ADDR_WR as literal down the code, like below:
    while(TIP[1] != 0)
You should have mentioned that you are using an opencores I2C master controller. https://opencores.com/project,i2c
I must confess that I don't understand how the code should wait for command completion. There's no interrupt defined that might change TIP[1]. So I assume, the while statement is simply skipped because TIP[1] is initially cleared. Did you copy the code somewhere?
Apart from this point, there's acknowledge polling for the EEPROM implemented in your code. `
    while(TIP[1] != 0)
it is checking that while loop.. i checked in debug mode.
now it is working fine. now it is checking ack bit as well as tip bit. i just replaced while loop like this while((IORD_32DIRECT(I2C_PIO_HW_0_BASE,I2C_SR))==1);
thank you for ur support.
