abhishekdixit
Full Member level 2
hello,
I am using PIC18F4550 micocontroller. i want to read the temprature from LM35 temprature sensor. for this i am using internal ADC of microcontroller & display this value on LCD. now i got success to enable the internal ADC of microcontroller. but its gives a wrong value on LCD.
please help me to remove this error.
my co& its proteus diagram shown below.
with regards,
Abhishek Dixit
#include<htc.h>
#include<string.h>
#define _XTAL_FREQ 20000000
#define rs PORTAbits.RA1
#define en PORTAbits.RA2
#define lcdport LATB
void lcd_ini();
void lcdcmd(unsigned char);
void lcddata(unsigned char);
void adc_con(unsigned int);
void adc_init();
unsigned char data[20]="ADC OUTPUT=";
unsigned int digital_out[10],avg_output=0,temp;
unsigned int i=0;
void main()
TRISA=0x01; // Configure RA0 as input pin
LATA=0;
TRISB=0; // Configure Port B as output port
LATB=0;
TRISD=0;
LATD=0;
ADCON0 = 0x00;
ADCON1 = 0b00001111;
CMCON = 0x07;
lcd_ini(); // LCD initialization
while(data[i]!='\0')
lcddata(data[i]); // Call lcddata function to send character one by from 'data' array
i++;
adc_init(); //ADC Initialization
while(1)
temp=0;
for(i=0;i<10;i++)
/*ADCON0|=(1<<GO); // Start A/D conversion
while(!(ADCON0 & (1<<GO)));*/ // Wait until conversion gets over
ADCON0=0x03;
while(GO!=0);
digital_out[i]=((ADRESL)|(ADRESH<<8)); // Store 10-bit output into a 16-bit variable
__delay_ms(20);
temp=temp+digital_out[i];
avg_output=temp/10; // Take average of ten digital values for stablity
adc_con(avg_output); // Function to convert the decimal vaule to its corresponding ASCII
void adc_init()
ADCON1=0x0E; // Make RA0/AN0 pin as analog pin (Other pins remain to be digital I/O)
ADCON0=0x00; // Select Channel0 & ADC off
ADCON2=0x8A; // Left justified, 2TAD acquiciation time, Fosc/32 clock option
ADCON0=0x01; // Enable ADC
void lcd_ini()
lcdcmd(0x38); // Configure the LCD in 8-bit mode, 2 line and 5x7 font
lcdcmd(0x0C); // Display On and Cursor Off
lcdcmd(0x01); // Clear display screen
lcdcmd(0x06); // Increment cursor
lcdcmd(0x80); // Set cursor position to 1st line, 1st column
void adc_con(unsigned int adc_out)
unsigned int adc_out1;
int i=0;
char position=0xC1;
for(i=0;i<=3;i++)
adc_out1=adc_out%10; // To exract the unit position digit
adc_out=adc_out/10;
lcdcmd(position);
lcddata(48+adc_out1); // Convert into its corresponding ASCII
position--;
void lcdcmd(unsigned char cmdout)
lcdport=cmdout; //Send command to lcdport=PORTB
rs=0;
// rw=0;
en=1;
__delay_ms(10);
en=0;
void lcddata(unsigned char dataout)
lcdport=dataout; //Send data to lcdport=PORTB
rs=1;
//rw=0;
en=1;
__delay_ms(10);
en=0;
with regards,
Abhishek Dixit
