Problem in displaying Characters in LCD Module
vamanan
Full Member level 2
India the Great
mov datalcd,#38h
I am interfacing LCD module with 8051.When I am executing the program, the data I am sending is just visible in the LCD
Module and immediately everything turns complete black.When I am switching the power off the data just visibles again in the
LCd for a moment and then everythings go to blank.Can anybody help me in curing my headache.
My programme is
; UNDER DEVELOPMENT
$MOD51
DATALCD EQU P2 ; DATA AT PORT 2
EN EQU P3.4 ;
RW EQU P3.5 ; EN, R/W, RS SIGNALS
RS EQU P3.6 ;
CHRNUM EQU 10H ; NUMBER OF CHARACTERS IN A LINE (16 CHARACTERS ie. 10H)
ORG 0000H
CALL INIT ; INITIALISE THE LCD MODULE
CALL CLEAR ; CLEAR THE LCD MODULE
MOV DPTR, #LINE1 ;
MOV R1, #CHRNUM ;
MOV A, #00H ; ROUTINE TO DISPLAY
MOV R2, #00H ; THE FIRST LINE
WRTL1: MOVC A, @A+DPTR ; FROM LOOKUP TABLE
CALL PUTTXT ;
INC R2 ;
MOV A, R2 ;
DJNZ R1, WRTL1 ;
CALL NEWLN
MOV DPTR, #LINE2 ;
MOV R1, #CHRNUM ;
MOV R2, #00H ; THE SECOND LINE
WRTL2: MOVC A, @A+DPTR ; FROM LOOKUP TABLE
CALL PUTTXT ;
INC R2 ;
MOV A, R2 ;
DJNZ R1, WRTL2 ;
SJMP $
INIT: SETB EN
CLR RS
CLR RW
MOV DATALCD, #38H
CLR EN
CALL WAIT
SETB EN
CLR RS
CLR RW
MOV DATALCD, #0EH
CLR EN
CALL WAIT
SETB EN
CLR RS
CLR RW
MOV DATALCD, #06H
CLR EN
CALL WAIT
RET
CLEAR: SETB EN
CLR RS
CLR RW
MOV DATALCD, #01H
CLR EN
CALL WAIT
RET
NEWLN: SETB EN
CLR RS
CLR RW
MOV DATALCD, #0C0H
CLR EN
CALL WAIT
RET
PUTTXT: SETB EN
SETB RS
CLR RW
MOV DATALCD, A
CLR EN
CALL WAIT
RET
WAIT: SETB EN
CLR RS
SETB RW
MOV DATALCD, #0FFH ; PORT2 INPUT MODE
MOV A, DATALCD
JB ACC.7, WAIT
CLR EN
CLR RW
RET
;;;;;;;;;; 'FFFFFFFFFFFFFFFF'
LINE1: DB 'xxxxxxxxxxxxxXXX'
LINE2: DB 'XXXXXXXXXXXXXXXX'
END
May be problem with CONTRAST setting ...
The contrast pin I permanently connected to ground.
Does it create any problem.
Try resistor 5k6 between Contrast pin and Gnd
Sento,
AFter connecting resistor as mentioned by you, the problem is solved.
Thanking You.
