[AVR] problem in AVRStudio timer interrupt subroutine
MISU.RSG
Member level 1
hi dear
I faced with a problem when I work with timers interrupt sub routine.
I used avrstudio 6.2. I wrote this code.
// ***************************** Timer 2 compare Subroutine *********************************
//							Start of function
void ISR (int TIMER2_COMP_vect){
	rsig_on;
	OCR2=pulse_value++;
	if (pulse_value==256)
	{	pulse_value=190;
reti();
//							End of Timer 0 compare Subroutine
// ***************************** Timer 2 overflow Subroutine *********************************
void ISR( TIMER2_OVF_vect){
	TCNT2=190;
	rsig_off;
	lsig_off;
//                          End of overflow Subroutine
after compiling I saw this error:
Error 2 redefinition of 'ISR'
what's my fault?
i don´t know much about C programming...
but in other examples there is no "void" before the "ISR". Could this cause the error?
Klaus
yep also
there's no need for that 'int' you just need to declare ISR(TIMER2_COMP_vect){ ... }
also, don't use reti(); it's only used when declaring a _NAKED_ interrupt routine, as yours aren't those, the compiler will add the correct instruction to return from the interrupt while restoring the rest of registers from stack...
