I found modules like above in netlist file.And I am finding this problem at all gates like nd 21d1.NOW tell me where i have to check whether its empty module or defined correctly or not.
Thanks
or21d1 was for other IP.
Here I had taken the example of small IP.
All the gates shown in RED are having the same problem....It is said for all gates in red that they are referenced but not defined.So plese explain it that where I have to define these and how.
from your last append I am almost sure you are not reading the libraries (technology libs) using which the netlist was synthesized - if you are then any one lib is missing
