Problem getting results from Peak Detector circuit
RDL
Newbie level 3
Newbie level 3
Edmonton, Canada
Further to the old discussion on https://www.edaboard.com/threads/298751/
I tried to use the first circuit illustrated. I have modified the drawing to illustrate the pins used and to show 9 Volts IN.
A 40 KHz signal input is giving no output, on the scope, which indicates a screw-up. Also attached is a photo of the breadboard to give you a better understanding of my problem. It may appear that the bottom 10K Resistor is in the wrong hole but the lead does bend inwards to connect with the Input which then leads to #2 of the CA3140.
After the laughter ceases is it possible to find out what is wrong or what I should measure?
Raymond
I fear the author from www.eleccircuits.com has problems with reading datasheets. He definitely mixed-up '+' and '-' input of the OP, creating positive instead of negative feedback.
O.K., it's not the author. There are no pin numbers in the original circuit. You better review a datasheet.
Reactions: RDL
    RDL
You are correct it was my mistake. Now, I exchanged the Input + to the #3 pin and #2 to the R2 10K.
The Output signal is still a flat line. A new CA3140 was inserted but there was no improvement.
This is the corrected Circuit Pin # and the revised breadboard that corrects the #2 and #3 Pin wiring error. The breadboard arrangement is still not giving an Output to the scope. Is there a measurement that I can attempt to give more information?
The CA3140 is very old. Its inputs do not work if they are within 2.5V from ground in this circuit. Its gain is low at 40kHz.
You need an opamp that has inputs that work when their voltage is at 0V like a TLE2141 or many other modern opamps. Its gain is pretty high at 40kHz.
Reactions: RDL
    RDL
It's true that CA3140 isn't best choice for a 40 kHz peak detector. On the other hand, the circuit parameters have to be adapted to the OP GBW and output impedance. Simply using an OP with higher GBW can cause overshoot of the peak detector and respective systematical error.
A substantiated circuit design would start with a complete specification.
I would add a transistor as an emitter-follower at the output of the opamp to provide lots of current to quickly charge the capacitor since the opamp by itself has a low output current.
Reactions: RDL
    RDL
Thank you for the response. I did try a TLE2141 but the circuit did not peak detect and hold. I concur with FvM that there is a need for a "substantiated circuit design" and so called in an expert to do the architecture.
