problem External interrupt RB0/INT in pic16f877
sanaprog
Newbie level 6
int run=0;
void interrupt(void){
INTCON.INTF = 0;
portd=~portd;
void main()
TRISB = 0x01;
PORTB=0;
TRISd = 0x00;
portd=0x3f;
INTCON.GIE = 1;
INTCON.INTE = 1;
intcon.intf=0;
INTCON.PEIE = 0;
OPTION_REG.INTEDG = 1;
do
}while(1);
can anyone tell me what is the wrong with this code...interrupt occurs but it returns to 0 if interrupt not given within few seconds....
Re: prolem External interrupt RB0/INT in pic16f877
What compiler are you using? And did you disable the watchdog timer in your configuration bit settings?
BigDog
THANKS for the reply...i am using mikro-c8....n how 2 set wdt off in mikro C...??in mPLAB i know its just ...#pragma config WDT = OFF... bt in mikro c:sad:
To set the Configuration Bits in MikroC,
Goto Menu:
"Project" -> "Edit Project ..."
BigDog
