Dec 18, 2008 #1 J jayce3390 Full Member level 6 Joined May 22, 2007 Messages 351 Helped 29 Reputation 58 Reaction score 21 Trophy points 1,298 Activity points 3,287 I want to install design kit but when I run a simulation the hpeesofsim window return to me "unable to locate "Auriga" library !!!! I check HOME/heesof/circuit/models and I find Auriga library in this directory. I don't understand... could you help me please.
Dec 19, 2008 #2 kspalla Advanced Member level 4 Joined Aug 19, 2008 Messages 1,253 Helped 258 Reputation 516 Reaction score 94 Trophy points 1,328 Location Hyderabad, Andhra Pradesh, India Activity points 6,813 Though it is present in the library. Some times we need to install /setup the kit to link to ADS. Just proceed with the install design kit procedure one more time.
Dec 19, 2008 #3 J jayce3390 Full Member level 6 Joined May 22, 2007 Messages 351 Helped 29 Reputation 58 Reaction score 21 Trophy points 1,298 Activity points 3,287 the problem is solved. ADSlibconfig file was not in config directory. thanks
