problem created in coding of 2bit and 3 bit flash
Aritra17
Junior Member level 3
kolkata
a problem occurs when i code 2bit flash adc using the 3bit flash adc code
the pattern of the output waveform changes completely
but i can't find the difference between the two codes
after all i have made the 2bit out of the 3bit by removing some coding lines that's it
but the waveform pattern changes
please help anyone
i am coding this flash adc's in tanner tools 7
i will be posting the codes of the two adcs
please check and reply
---------- Post added at 16:55 ---------- Previous post was at 16:54 ----------
2bit flash adc
**comparator**
.subckt cmp in ref out Vdd Gnd
M1 Gnd ref N3 Gnd Nh L=.15u W=1u AD=66p PD=24u AS=66p PS=24u
M2 N3 ref bufr Gnd Nh L=.15u W=11u AD=66p PD=24u AS=66p PS=24u
M3 N2 in N3 Gnd Nh L=.15u W=11u AD=66p PD=24u AS=66p PS=24u
M4 N4 bufr Gnd Gnd Nh L=.15u W=2u AD=66p PD=24u AS=66p PS=24u
M5 OUT N4 Gnd Gnd Nh L=.15u W=.5u AD=66p PD=24u AS=66p PS=24u
M6 N4 bufr Vdd Vdd Ph L=.15u W=20u AD=66p PD=24u AS=66p PS=24u
M7 Vdd N2 N2 Vdd Ph L=.5u W=6u AD=66p PD=24u AS=66p PS=24u
M8 bufr N2 Vdd Vdd Ph L=.5u W=6u AD=66p PD=24u AS=66p PS=24u
M9 OUT N4 Vdd Vdd Ph L=.15u W=15u AD=66p PD=24u AS=66p PS=24u
.ends cmp
**resistor(.5)**
.subckt res in out
R1 in out 0.5 TC=0.0, 0.0
.ends res
**resistor(1)**
.subckt rest in out
R1 in out 1 TC=0.0, 0.0
.ends rest
**xor**
.subckt xor a b out Vdd Gnd
M1 abar a Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M2 bbar b Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M3 b abar bufr Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M4 bbar a bufr Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M5 N2 bufr Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M6 out N2 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M7 abar a Vdd Vdd Ph L=.15u W=2u AD=66p PD=24u AS=66p PS=24u
M8 bbar b Vdd Vdd Ph L=.15u W=2u AD=66p PD=24u AS=66p PS=24u
M9 b a bufr Vdd Ph L=.15u W=2u AD=66p PD=24u AS=66p PS=24u
M10 bbar abar bufr Vdd Ph L=.15u W=2u AD=66p PD=24u AS=66p PS=24u
M11 N2 bufr Vdd Vdd Ph L=.15u W=2u AD=66p PD=24u AS=66p PS=24u
M12 out N2 Vdd Vdd Ph L=.15u W=2u AD=66p PD=24u AS=66p PS=24u
.ends xor
**buffer**
.subckt buff a b Vdd Gnd
M1 N4 a Gnd Gnd Nh L=.15u W=2u AD=66p PD=24u AS=66p PS=24u
M2 b N4 Gnd Gnd Nh L=.15u W=.5u AD=66p PD=24u AS=66p PS=24u
M3 N4 a Vdd Vdd Ph L=.15u W=20u AD=66p PD=24u AS=66p PS=24u
M4 b N4 Vdd Vdd Ph L=.15u W=15u AD=66p PD=24u AS=66p PS=24u
.ends buff
**encoder**
.subckt enco d1 d2 d3 e2 e1 Vdd Gnd
M1 e1 d1 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M2 Gnd d2 e2 Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M3 e2 d3 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M4 e1 d3 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M5 Vdd Gnd e2 Vdd Ph L=.15u W=.6u AD=66p PD=24u AS=66p PS=24u
M6 Vdd Gnd e1 Vdd Ph L=.15u W=.6u AD=66p PD=24u AS=66p PS=24u
.ends enco
**circuit**
**resistance ladder**
Xres_1 ref r1 res
Xrest_1 r1 r2 rest
Xrest_2 r2 r3 rest
Xres_2 r3 Gnd res
**comparator**
Xcmp_1 in r1 c1 Vdd Gnd cmp
Xcmp_2 in r2 c2 Vdd Gnd cmp
Xcmp_3 in r3 c3 Vdd Gnd cmp
**generator**
Xxor_1 Gnd c1 x1 Vdd Gnd xor
Xxor_2 c1 c2 x2 Vdd Gnd xor
Xxor_3 c2 c3 x3 Vdd Gnd xor
**encoder**
Xenco_1 x1 x2 x3 e2 e1 Vdd Gnd enco
**buffer**
Xbuff_1 e1 b1 Vdd Gnd buff
Xbuff_2 e2 b2 Vdd Gnd buff
**simulation**
v27 ref Gnd 3.0
v28 in Gnd sin 0 5.0 1000000 0.0 0.0 0.0
Vdd Vdd Gnd 5V
.dc v27 0 3.0 0.1
.tran 1n 1200n
.include dual.md
.power(Vdd)
.print v(in) v(ref) v(b2) v(b1)
---------- Post added at 16:56 ---------- Previous post was at 16:55 ----------
3bit flash adc
**comparator**
.ends cmp
**resistor(.5)**
.subckt res in out
.ends res
**resistor(1)**
.subckt rest in out
.ends rest
**xor**
.ends xor
**buffer**
.ends buff
**encoder**
.subckt enco d1 d2 d3 d4 d5 d6 d7 e3 e2 e1 Vdd Gnd
M1 buff1 d1 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M2 Gnd d2 buff2 Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M3 buff2 d3 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M4 buff1 d3 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M5 Gnd d4 buff3 Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M6 buff3 d5 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M7 buff3 d6 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M8 Gnd d7 buff3 Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M9 buff2 d6 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M10 Gnd d7 buff2 Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M11 buff1 d5 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M12 Gnd d7 buff1 Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M13 N1 buff2 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M14 e2 N1 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M15 N3 buff3 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M16 e3 N3 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M17 N4 buff1 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M18 e1 N4 Gnd Gnd Nh L=.15u W=.3u AD=66p PD=24u AS=66p PS=24u
M19 Vdd Gnd buff3 Vdd Ph L=.15u W=.6u AD=66p PD=24u AS=66p PS=24u
M20 Vdd Gnd buff2 Vdd Ph L=.15u W=.6u AD=66p PD=24u AS=66p PS=24u
M21 Vdd Gnd buff1 Vdd Ph L=.15u W=.6u AD=66p PD=24u AS=66p PS=24u
M22 N1 buff2 Vdd Vdd Ph L=.15u W=.6u AD=66p PD=24u AS=66p PS=24u
M23 e2 N1 Vdd Vdd Ph L=.15u W=.6u AD=66p PD=24u AS=66p PS=24u
M24 N3 buff3 Vdd Vdd Ph L=.15u W=.6u AD=66p PD=24u AS=66p PS=24u
M25 e3 N3 Vdd Vdd Ph L=.15u W=.6u AD=66p PD=24u AS=66p PS=24u
M26 N4 buff1 Vdd Vdd Ph L=.15u W=.6u AD=66p PD=24u AS=66p PS=24u
M27 e1 N4 Vdd Vdd Ph L=.15u W=.6u AD=66p PD=24u AS=66p PS=24u
.ends enco
**circuit**
Xres_1 ref r1 res
Xrest_1 r1 r2 rest
Xrest_2 r2 r3 rest
Xrest_3 r3 r4 rest
Xrest_4 r4 r5 rest
Xrest_5 r5 r6 rest
Xrest_6 r6 r7 rest
Xres_2 r7 Gnd res
**comparator**
Xcmp_4 in r4 c4 Vdd Gnd cmp
Xcmp_5 in r5 c5 Vdd Gnd cmp
Xcmp_6 in r6 c6 Vdd Gnd cmp
Xcmp_7 in r7 c7 Vdd Gnd cmp
**generator**
Xxor_4 c3 c4 x4 Vdd Gnd xor
Xxor_5 c4 c5 x5 Vdd Gnd xor
Xxor_6 c5 c6 x6 Vdd Gnd xor
Xxor_7 c6 c7 x7 Vdd Gnd xor
**encoder**
Xenco_1 x1 x2 x3 x4 x5 x6 x7 e3 e2 e1 Vdd Gnd enco
**buffer**
Xbuff_3 e3 b3 Vdd Gnd buff
**simulation**
v27 ref Gnd 3.0
Vdd Vdd Gnd 5V
.dc v27 0 3.0 0.1
.tran 1n 1200n
.include dual.md
.power(Vdd)
.print v(in) v(ref) v(b3) v(b2) v(b1)
