[SOLVED] problem about scanning 3x4 keypad in verilog
pkl520
Newbie level 1
Newbie level 1
hello i'm new here and a beginner in verilog
i have problem about scanning 3x4 keypad in verilog
above is question
now i already have 4-2 priority encoder to put row&column into keypad scanning and then
put data into binary to bcd converter
but now i'm stuck here. because i dont know how to put data into binary to bcd converter
can some give a help or hint?
i will be apreciate.
p.s: the attachment is my verilog code
module prio_encoder4_2 ( d0,d1,d2,d3 ,x ,y );
input d0 ;
input d1 ;
input d2 ;
input d3 ;
output reg  x ;
output reg  y ;
always @ (d0 or d1 or d2 or d3)
  if (d3 == 1)
  {x,y} = 3'b11 ;
else if (d2 == 1)
  {x,y} = 3'b10 ;
else if (d1 == 1)
  {x,y} = 3'b01 ;
else if (d0 == 1)
  {x,y} = 3'b00 ;
else
  {x,y} = 3'bxx ;
endmodule
module matrix_scan(co1,row,a1,b1,c1,d1);//a1~d1 is output
input [3:0] co1;
input [3:0] row;
output a1;
output b1;
output c1;
output d1;
prio_encoder4_2 en1(.d0(co1[0]) ,.d1(co1[1]) ,.d2(co1[2]) ,.d3(co1[3]) ,.x(a1) ,.y(b1) );
prio_encoder4_2 en2(.d0(row[0]) ,.d1(row[1]) ,.d2(row[2]) ,.d3(row[3]) ,.x(c1) ,.y(d1) );
endmodule
module add3(in,out);
input [3:0] in;
output [3:0] out;
reg [3:0] out;
matrix_scan aa(.co1(co1),.row(co1),.a(in[0]),.b(in[1]),.c(in[2]),.d(in[3]));//have problem here~!!!
always @ (in)
 case (in)
 4'b0000: out <= 4'b0000;
 4'b0001: out <= 4'b0001;
 4'b0010: out <= 4'b0010;
 4'b0011: out <= 4'b0011;
 4'b0100: out <= 4'b0100;
 4'b0101: out <= 4'b1000;
 4'b0110: out <= 4'b1001;
 4'b0111: out <= 4'b1010;
 4'b1000: out <= 4'b1011;
 4'b1001: out <= 4'b1100;
 default: out <= 4'b0000;
  endcase
endmodule
module seg7 (bcd, leds);
	input [3:0] bcd;
	output [1:7] leds;
	reg [1:7] leds;
	always @(bcd)
		case (bcd)       //abcdefg
			0: leds = 7'b1111110;
	   		1: leds = 7'b0110000;
			2: leds = 7'b1101101;
			3: leds = 7'b1111001;
			4: leds = 7'b0110011;
			5: leds = 7'b1011011;
			6: leds = 7'b1011111;
			7: leds = 7'b1110000;
			8: leds = 7'b1111111;
			9: leds = 7'b1111011;
			default: leds = 7'bx;
		endcase
endmodule
We aren't going to do your homework for you...but I'll give you a hint.
The table in your picture of the problem statement shows that the codes that come out on ABCD need to be translated to BCD (i.e. Binary Coded Decimal). To perform logic transformation of some inputs into new outputs can be done by using a truth table.
LaTeX Commands Quick-Menu:
