william_luo
Junior Member level 2
- Joined
- Mar 25, 2013
- Messages
- 23
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Activity points
- 1,465
Hi everyone,
I need copy some design files (just schematic and symbol part) from 45nm process library to 15nm process library because I am interested in the comparison between them. Basic cells (NAND, XOR etc.) satisfying new size are given with the same library name. Then I moved high level files to the new directory. But when I opened new schematic in the new library, I found that the coordinate position of instances(just Basic Cells) are all changed a little bit while wire and pins are still there. So the ports of instances and corresponding wires are staggered. I need move those instances to the right position manually. But when the circuit is big it will be too much trouble. Then what should I do?
Thanks in advance!
Wayne
Thanks in advance!
Wayne
