mvagusta
Junior Member level 2
I was wondering why people use opto-isolators/couplers to run extra leds from a mobo led header, such as a 4N28, instead of just using a much cheaper solution such as a bc548 & resistor?
Do we really need that much isolation? I haven't tried it but i'm fairly sure using a simple bc548 as a switch would work fine. I think both the 4N28 & bc548 have 100ma collector current continous ratings, so why spend the extra money on an opto-isolator such as a 4N28?
You could even get a bc639 with a massive 1a contious rating for less than half the cost of the 4N28! The cheaper bc548 & bc639 solutions are even slightly more compact in thier TO-92 cases! Cheaper & smaller...
Jaycar in aus sell 4N28 for $1.40, and bc548 for $0.26, bc639 for $.60, and resistors are like nothing.There must be an advantage i am missing here, it just doesn't seem correct?
Wait, is it possibly of the tiny risk of a transistor failing and shorting collector to base, sending the supply voltage into the mobo header? Is this risk not a possibility or have i answered my own question? So maybe if you want more current capability than the 4n28 provides, you use the 4N28 to trigger a large transistor?
