PRO**TEUS, VTERM and PIC USART Problem.
neuralc
Full Member level 4
Full Member level 4
compim & vterm
Hi all,
I'm trying to simulate a program with a PIC->PC communication. For that I use Pro**Teus with the VTERM module connected to the RX/TX of the 16F870 USART.
For error checking I'm using the 9th bit of the usart to send the EVEN parity bit. After simulate on MPLAB I see that the bit TX9D(9th bit) is correctly set (When we need it to get EVEN number of 1's) but on PRO**TEUS (new version SP6) the bit never change the value, neither set it on the code the value it's always zero.
So, for everybody that want simulates this functionality be careful.
NeuralC
compim vterm even
send me a copy of the problem
put in in a folder called problem
within sp6 in fm1
and let me know then i can see further the problem
perhaps will be easy when i see dsn....
ok
after reading again
i see the problem
you cannot affix parity to the data stream
this isnt common practice
parity must be its own
bit {port pin}
so parity non parity toggle can be preserved
in sync
or youll get buffer under / overruns
and funny results
i think your daft to use this
but i also think you need to set the compim to 9 bit even parity 1 start and youll need a stop bit {port pin} also
to locate the 8 th data bit in the stream for stacking....
so parity flop can easily be read in sync
and baud sync status preserved
so i think it will be an incorrect setting somewhere
serial can be a nightmare
