Jul 15, 2010 #1 G Giacomo Leopardi Newbie level 4 Joined May 31, 2010 Messages 6 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location Italy Activity points 1,317 To print the currents of a mos (named M_1) in a subcircuit (for every istance of the subcircuit), I use this HSpice comand: .PRINT iall(x*.M_1) the currents appear in the .lis file (in tabular format), but they are not visible with AvanWaves. So, how I can view this currents? Thanks
Sep 14, 2010 #2 N nafraf Member level 5 Joined May 2, 2002 Messages 86 Helped 6 Reputation 12 Reaction score 3 Trophy points 1,288 Activity points 490 You should use .PROBE command to save output variables into the interface and graph data files.
Nov 11, 2010 #3 S shravan87 Junior Member level 3 Joined May 29, 2010 Messages 29 Helped 11 Reputation 22 Reaction score 11 Trophy points 1,283 Location USA Activity points 1,441 Use the .probe command. If you are doing transient analysis, then open the .tr0 file that will be created in a graphical viewer to see your waveforms.
