Printing of node to node capacitance using SPICE
vignesh_9
Newbie level 3
How to print nodal capacitance table using spice? Could someone please guide me on this.
erikl
Super Moderator
Staff member
Germany
RTFM!
.OPTION CAPTAB
SYNTAX:
.OPTION CAPTAB
DESCRIPTION:
Prints table of single-plate node capacitances, for diodes, BJTs, MOSFETs, JFETs, and passive capacitors, at each operating point.
vignesh_9
Newbie level 3
Re: RTFM!
.OPTION CAPTAB
SYNTAX:
.OPTION CAPTAB
DESCRIPTION:
Thanks for your instant help.
Could you please tell me what is the command used to print the capacitance i.e
after using .OPTION CAPTAB
if i want the capacitance at node N1
how do I print it
Its not working with the following command :
capacitor test
.lib 'cmos180n.lib' tm
.include 'digital.inc'
.include 'mos-subcirc.inc'
r1 1 2 1.0k
c1 2 0 1.0p
c2 2 0 1.0p
c3 2 0 1.0p
v1 1 0 dc 2
.control
destroy all
option CAPTAB
op
print vm(2)
print CAP(2)
.endc
.end
erikl
Super Moderator
Staff member
Germany
.option !!!
.OPTION captab
prints all capacitances
You forgot the dot in front of the option
h_vogt
Member level 1
SPICE == HSPICE ?
.OPTION captab is a HSPICE option.
What SPICE are you using?
vignesh_9
Newbie level 3
SPICE == HSPICE ?
I am Using SPICE OPUS.
And I had put OPTIONS CAPTAB inside
.CONTROL
.ENDC
I assume i need not use .OPTIONS rather can use OPTIONS directly.
vignesh_9
Newbie level 3
I checked in the Spice Opus manual, there is no such option "option CAPTAB". Anyways thanks for the other link let me see if that would help :-|
