PrimeTime SI vs. Celtic
steven852
celtic vs primetime
Can someone give a quick outline of the difference between PrimeTime SI and Celtic?
Thanks in advance.
stormwolf
primetime-si
I have heard from cadence sales, they said celtic first generate a timing file through a spice engine, so it timing more true than PT-SI.
sarath51
Full Member level 2
celtic primetime-si
for noise analysis Celtic does a better job. so usually for Post route timing and Cross talk PT is used and for noise analysis Celtic is used
shankarmit
Full Member level 3
India
primetime celtic
bot as used for signal integrity analysis... celtic is from cadence and pt si from synopsys....
In general celtic is better in signal integrity..
rakeshnunna
Member level 4
si analysis with primetime
People familiar with PT will find using PT-SI easy to learn and use.Its a good tool as well. Celtic is very good for noise analysis but little bit difficult to learn and use.
In the end it depend s upon the project needs like technology you are working, which
company flow you are using, and rampup time you are having
p_shinde
Full Member level 5
tokyo
runtimes of celtic,primetimesi,spice
one Q on noise analysis, one should first wrok on aggressor or victim in an affected circuit...........using CeltIC????????????
thanks,
Prasad
shankarmit
Full Member level 3
India
primetime si
mostly victim .. because if u try to move aggressive it may affect at some other place..... it all depends on the metal available to move or sheiding can be done..
Regards
Shankar
jitendra
Member level 3
India
Run time is one more concern to make choice between PT-SI and PT with CeltIC.
PT-SI takes longer time.
