Preventive repair a Gysmi 161 arc welder
DeepOne
Advanced Member level 2
45N39E, Russia
Known that main problem with these device is bad soldered to power charge current conducting racks. They easy come off even under small blow or without visible reasons in general. This quite often occurs after completion of the period of the warranty. Thereby better to solder these join, not waiting a blast of the welding device.
Since lower side rectifier in this device consist from six STTH2003CG (2х10А, 300V, 35ns) diodes is better not to exceed 120А current, in spite of that producer is declared 160A max.
This design also exists under names "GYS", "Fubag", "IMS", "Inverter 4000", "Spark" and so on, and so forth.
  • GYSMI161.pdf
Hello.. would you please help me to find out what are the 2 components in circles?
thaaaank you ....
thank you so much for this help from your heaaart
my dad is glad he can fix it now :smile:
i am into natural medicine and healing devices, meditation and energy works for many years... if u need anything please email me
alaa (at) alaalsayid . com
grateful to u
