nimmerlein
Newbie
I have a "circuit" which is a (fairly large, 25x25 cm) square grid of 1mm wide microstrip lines on a 1mm thick substrate (PTFE with epsilon of 2.2). Operation frequency is around 20 GHz.
Reflections from the edges of that grid, which are just stubs of a few mm length where the microstrips have been cut off, unfortunately have appeared to be a bit more of a problem than first anticipated.
So, now I am looking for a good way of preventing these reflections. "Good" would ideally mean that I would not have to use lumped components (I would need many of them because obviously there are a lot of stubs to be terminated which would (a) probably be pricy and (b) be a pain to solder on, especially since the ground plane of the circuit is large which makes this difficult) and even more ideally would not require to modify the circuit design (because then I could just retrofit it to the board I already got made). I was thinking along the lines of adding some sort of lossy material (foil? foam?) to the edges, tapered in some way to match it to the microstrips, but I am of course happy about any kind of suggestion.
