[SOLVED] Preprocessor error in C
shaswat
Full Member level 1
I tried to run a simple preprocessor code on my code-block 13.12 IDE. But it shows an error
error: request for member 'b' in something not a structure or union|
Here is the piece of code:
#define CUBE(x) (x.x.x)
main()
    int  a,  b=3 ;
    a =  CUBE(b++);
    printf (  "\n%d  %d",  a,  b  )  ;
Even I am not using any structure and union in my code...
Any help?
Simple solution. As b isn't a structure, don't apply structure syntax (x.x.x) to it...
What do you want to achieve with "x.x.x" ?
Nothing much as I want to just brush up my preprocessor fundamentals, saw that piece of code and I was expecting some output rather than an "ERROR".
What would be the solution then? I think that this type of error I never got when executed on TURBO C compiler.
I guess you want to define cube function with #define macro so
Code C - [expand]
#define CUBE(int x)   x*x*x
as answered earlier you are using .(dot) for multiplication insted of *(star)
Code C - [expand]
Such an idiotic point that I missed.
Ssshit That was definitely bcoz of my brain break down .
