Preliminary Question in an ADC terminlogy
santom
Full Member level 2
Full Member level 2
I have got a very basic doubt suddenly.Thought I should ask you people here so that I get cleared and also others in future if they are equally confused like how I am now
In a 10 bit SAR ADC, for example if the sampling frequency is 2 KHz, then the entire conversion cycle takes place in 11 clock cycles(including reset phase as well) and so the internal clock frequency should be 11 times faster(22 KHz)
My question is, is it then we should give a 1 KHz input signal to test the ADC as the sampling frequency set is 2 KHz in order to obey the sampling theorem.
Or Am I wrong... Help me people. Thanks a bunch
Peace out
Santom
Kral
USA
Your numbers are correct, assuming that 1 internal clock cycle provides enough time for overhead such as reset and output data transfer.
Reactions: santom
    santom
santom
Full Member level 2
Full Member level 2
thanks ..but is it possible to take 12 times faster clock too? i mean , can i use 12 clock cycles instead of 11 clock cycles for one conversion cycle?
Kral
USA
You can use a faster clock. The important thing is that the conversion is fast enough to allow at least 2 samples for each cycle of the the highest frequency input signal of interest.
