Predicting maximum current flow of diode in half/full-wave rectifier
t0mbst0n3
Newbie level 3
Diode forward voltage drop = 0.6 V
R3 = 18 kΩ
Vs = 10sin(2π*10000t) V
Half wave rectifier circuit diagram:
Full wave rectifier circuit diagram:
How do you predict the maximum current flow for the D1 diode for both scenarios? I'm stuck at this part because the Vs value has an unknown variable.
KlausST
Super Moderator
Staff member
What do you mean with unpredictable variable?
In any case you know it's a sinwave and you know it's amplitude.
Thus the max voltage is clear.
And because there is an ohmic load .... just use Ohm's law.
Klaus
t0mbst0n3
Newbie level 3
Klaus
Sorry, I don't get you at the "it's a sinwave and you know its amplitude." Amplitude is 10, so therefore maximum voltage is 10? Then what is the point of the Vs equation?
KlausST
Super Moderator
Staff member
Correct. This is true for every pure sinewave.
That´s not the question.
But maybe it´s just to check if you recognize that the max voltage is 10V.
Klaus
FvM
Super Moderator
Staff member
Bochum, Germany
Diode current is equal to I(R3) = Vo/R3. You want to calculate Vo, which is Vs - diode voltage drop (0.6 or 1.2 V respectively).
There's no D1 in circuit 2, b.t.w. Apparently you mean a different diode.
t0mbst0n3
Newbie level 3
Alright, understood.
For circuit 1, Vo = Vs - 0.6 because there is only one diode, yes? Just want to confirm.
For circuit 2, the diode current must be found for either D3/D4/D5/D6, since all four diodes share the same forward voltage drop = 0.6 V. So based on that logic, would the diode current be equal to I(R3,4,5,6) = Vo/R3, where Vo = Vs - 0.6 - 0.6 ? I assume this to be the case because there out of four diodes, two diodes are in series with each other with the other two diodes being in series with each other.
FvM
Super Moderator
Staff member
Bochum, Germany
Voltage drop of the bridge rectifier is always 1.2V.
KlausST
Super Moderator
Staff member
Just to clarify: In an usual bridge recitifier circuit:
* for the positive halfwave diodes right_top and left_bottom are active and thus these two are connected in series.
* for the negative halfwave diodes left_top and right_bottom are active and thus these two are connected in series.
... although these diodes don´t have direct connection at the bridge rectifier circuit.
Klaus
